Cleaning skulls
/ Cleaning skulls #1
freedomlives
Platinum Member
Husak, Slovakia, EU
Iseki TS35F, Goldoni Special 140 with powered trailer -- Goldoni Special 128 -- Goldoni Uno for mowing -- Czech Vari system
Our first billy goat died this summer, while I was away actually, so his body was just left by an ant pile for nature to do its thing, and that pretty much left a clean skull, though a bit smelly.
Unfortunately, wolves or wild/stray dogs got to our goats last month and killed a few, including the new billy goat.
I have this friend who likes animals skulls for decoration, so I've promised her those of both billy goats (as well as some other goats/sheep when slaughtering time comes) but does anyone know a good way to get them clean beyond just leaving them outside awhile? Ideally, de-odorized too?
/ Cleaning skulls #3
The only way I've done it is to boil out the skull in a big pot.
You may want to do this outside. Keep the skull entirely submerged in the boiling water.
/ Cleaning skulls #4
Necrophila americana - or Carrion Beetle. They used to use them in the biology lab to clean skulls back in college. Also boiled them clean and would soak in a light bleach solution to help whiten them up when completed.
/ Cleaning skulls #5
I just buried mine for about 6 months. Make sure it is all the way under ground or the mice may chew the horns. Some taxidermists have the beetles for skull only mounts.
/ Cleaning skulls #6
1961 - my second year in Alaska. Worked with a biologist doing a study on the Arctic Shrew. His study needed 25 cleaned shrew skulls. What a real PITA. No problem catching and euthanizing the little beasties. It was NOT so much fun picking the skin and flesh off a skull the size of your little fingernail. We used what are called Micro-tweezers. Then we boiled them. Learned, right off, boiling doesn't take long for a shrew skull.
/ Cleaning skulls #7
We always added a tablespoon or two of Borax to the water while boiling. Just depended on the size of the pot.
After boiling and additional cleaning, a warm water bath with some bleach to whiten the skull.
/ Cleaning skulls #8
If you are going to boil the head, skin it first. Be careful as the skull is very soft and your knife will easily scratch it.
/ Cleaning skulls #9
Have you ever smelled Arctic Shrew soup??
/ Cleaning skulls
Thanks for all the advice. It goes without saying that the heads will be boiled outside-- I have a wife.
The European species of carrion beetle exists in some parts of Slovakia, and I swear I've seen it before, but probably am not going to be able to find it with these temperatures.
/ Cleaning skulls #11
Andrew - I don't know how "rural" you are there. Boiling the head outside is DEFINITELY the way to go. The "smell" would linger inside the house for quite a while. A couple other points. Keep an eye on the operation. While it might not smell so good to us - it could attract unwanted "others". A wandering cat, perhaps a raccoon, a local dog. Something that might want the skull. It might also attract mice or weasels but if you have a pretty good sized pot - there won't be much they can do.
Many will do an operation, like this, in their garage or closed out building. Keeps visitors at bay.
Also - it is entirely possible to over boil a skull. The skull will break down to its component parts. You would have to fit & glue it back together. So check the boiling process often. When everything( all the flesh ) has fallen off or can be easily removed - that's pretty much it.
Then, if you want a bright white skull - as Fossil Farm says - a warm water bath with some bleach.
A final note - dump the water in the pot a good long distance from any of your buildings. No need to attract visitors to any of your close in operations.
If you get a chance - take a couple pictures of the final product and post here on TBN.
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
2024 SANY 2Y26U EXCAVATOR (A65056)
2024 SANY 2Y26U...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2011 FOREST RIVER T/A CARGO TRAILER (A67714)
2011 FOREST RIVER...
