Cleaning PT 1850 Hydraulic Tank
   / Cleaning PT 1850 Hydraulic Tank #1
SpringHollow
Elite Member
South of Rochester, NY
Power Trac 1850, NH 2120
Hi Carl,
Here are the pictures you asked for.
The first picture is of the inside of the tank before cleaning. The mess on the bottom was thick enough that it did not drain out even though I jacked up the other side of the tractor to aid in draining.
The second picture is the smaller return tank. Notice how much cleaner it is. So much more settles in the supply tank because of its size (lower velocity, greater dwell time). I would have preferred that the supply tank be the cleaner one but maybe it would starve the pumps which would be real bad or keep too much in suspension.
Sorry about the copyrights - I had it defaulted to add it because of another project I was working on.
Here is the tank after cleaning it with paper towels.
You can see the openings fo the supplies to the pumps and the gap underneath the passage tunnel. The baffle on the other side of the tunnel which separates the supply and return tanks is gapped at the front of the tank.
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
FAKE (A52472)
FAKE (A52472)
