Cleaning my mower deck
/ Cleaning my mower deck #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
Well, I never could get my mower high enough off the ground using car ramps. I ended up laying on the ground getting all grassy and wet while power washing the underside of the mower. Here's how I've been doing it the last two summers.
Here's the mower.
Here's the two hooks I attached to the front. I know they are not designed for anything similiar to this purpose, but they work just fine and they are what I had laying around at the time.
This photo shows how I attach a loop of chain to the tractor bucket.
Leaving a generous loop of chain hanging down allows me to see the chain from the tractor seat for easy hook-up. (all from the seat)
Next, I just hook-up and lift. My first experience with this was hair-raising !! Turns out, I needed filled tires. With the extra ballast in the rear I can lift the mower as high as I want. Though I have'nt tried, I believe I could lift it right off the ground.
See, you thought the hooks would bend, did'nt you ? /forums/images/graemlins/shocked.gif
They don't. Relax, I've done this many times /forums/images/graemlins/laugh.gif
Here's the crud I need to blast out of there /forums/images/graemlins/frown.gif
I can now crouch down and power wash the deck. I get a little dirty from the 'blow-back', but it's much better than laying on the ground.
/forums/images/graemlins/smirk.gif Hmmm, now I'm wondering if I can use the same technique to wash the bottom of my car. /forums/images/graemlins/smirk.gif
Ooops /forums/images/graemlins/frown.gif better get a bigger tractor /forums/images/graemlins/wink.gif
Disclaimer:
For those of you who are a bit worried at this point, you should know that I don't get under the mower or the loader while lifting, lowering, or cleaning.
The only time I do get under there is when I change the blades. Not much choice there.
/ Cleaning my mower deck #9
Do you block up the deck with cinder blocks, jack stands or some other solid object when you get under to change the blades? Those hooks do look kind of light weight, and those bolts could rust and weaken over the years.
/ Cleaning my mower deck #10
Something that might work for you would be a tounge from a mobil home. There are quite a few of them around as folks with their own property want them off their home. I paid $40 for one the other day to make a skid to suspend logs over my splitter. You could make a angled ramp with a single tounge, and get it up higher than with car ramps. At least you'd have it sitting on something solid when you need to get under it.
/ Cleaning my mower deck #11
<font color="red"> </font> See, you thought the hooks would bend, did'nt you ?
I was worried when you were talking about lifting up the mower to clean under the deck, and I saw a swimming pool in the background /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
Ah, great idea ! Dip the mower in the pool and then hang to drip dry. /forums/images/graemlins/laugh.gif Brilliant ! /forums/images/graemlins/grin.gif
/ Cleaning my mower deck #13
You could get a backhoe, dig a pit like the Oil change places.
and work from underneath.
Danny /forums/images/graemlins/wink.gif
/ Cleaning my mower deck #14
The key to your method is having a FEL.
With my old 42" lawn tractor, the deck doesn't come off easy, so I reach my hand underneath and grab the gunk best I can. Sometimes I use car ramps, sometimes not.
But with my new 54" JD I'm waiting to get delivered, my plan is take the deck off and clean. I'll see how easy that is. Supposed to be quick detatch. And the deck wheels rotate so it should slide out ok. Plus, since I plan on using a front blade for playing around, I should get used to taking the deck off and putting it back on.
Anyway, that's my plan.
/ Cleaning my mower deck #15
I've used several methods with my 42" lawn tractor: Reaching underneath, car ramps and picking up the front wheels with the FEL on my tractor.
Now I've rigged up a light duty chain hoist from Northern Tools in the overhead of my garage. I lay out a tarp, roll the nose of the lawn tractor up to the chain hoist and raise it up to about a 30 degree angle. Put a short 6 x 6 block under the front for safety then reach under and scrape off the crud onto the tarp.
/ Cleaning my mower deck #16
I had a JD 430 L&G for 18 years and I now have a JD X595 and that's how I service my decks also. Works great and is fast if you have the FEL handy. I use jack stands if I need to get under there myself to change blades and etc. I don't have the fancy hooks like you do /forums/images/graemlins/frown.gif but it does work great and if someone has a better way to do it, I would like to hear about it. Removing the deck is a little more involved than I would like even though it's not a big deal.
I have thought about welding up a steeper ramp to drive up onto that would put the tractor up at about a 45 degree angle or maybe a little more. If I can get my hands on some good steel grid (like they use on cat walks, etc) I may attempt to make a special ramp. /forums/images/graemlins/cool.gif
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2001 Kubota L3010 (A64126)
2001 Kubota L3010...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2007 Flatbed Dump (A62613)
2007 Flatbed Dump...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
