Cleaning debris from woods
   / Cleaning debris from woods #11
I’d burnt it and if moving is required use a grapple. You could rent a tracked skid steer or just use the rental money for a tire patch if needed.
   / Cleaning debris from woods #12
I've dug a rather large hole - 35' in diameter, about 6' deep - out in the center of one of my open fields. I put all the "crap" I find on the 80 in that hole and have at least one big bonfire every winter. My 80 was part of a much larger 1890's homestead and I'm always finding building materials, old rotten fence posts, miles & miles of old "flat barbed" barb wire etc, etc. It all goes in the hole.
BTW - burning any old steel wire, of any kind, increases the rusting and decomposition tremendously.
   / Cleaning debris from woods #13
   / Cleaning debris from woods #14
In a lot of places, recreational fires are permitted.... wrap a couple potatoes in foil and toss them in the fire just in case.... ;)
Or a package of hot dogs and some sticks "waiting for the fire to burn down enough to cook on it officer"
Aaron Z
   / Cleaning debris from woods #15
burying debris or burning is illegal around here so I'd go with your method of flagging the piles so you can see what you are dealing with and what size dumpster you may need.......I agree that a grapple bucket is the way to go.........Jack
So... You are required to PAY someone else to haul it off and burn or bury it?
   / Cleaning debris from woods #16
SCHMIDT - jfh28 - burying debris on your own property is not legal in your part of PA??? Lord 'A Goshen - may I die in peace here in Ea WA.
   / Cleaning debris from woods #17
Unfortunately a very common practice;all of our old farms have junk piles somewhere.Lots of old machinery
and house hold goods.Most will not burn;metal ,glass ect.We filled one large roll-off and still didn't get it all.
Some sort of grapple or hire some-one with a skid-steer if you like your tires!
   / Cleaning debris from woods #18
My 80 acres was part of an original 1892 - 360 acre - homestead. About two years after we moved here I found where the old homesteader "relocated" a lot of his unwanted materials. Old metal food, paint, oil etc cans - glass containers of all kinds and descriptions - many earthenware pots and jugs - and the most unusual - almost an entire standard sized pallet of old dry cell batteries. Since there never was or ever has been land line phone service here - I can only surmise they were used to power some type of radio - probably the old couples only form of entertainment.
This 80 acres of mine is so remote - that until I had a driveway built in 1982 - there never has been an official or established driveway to this property. The old homesteader here had a great old Model T and he told of times he would drive it into town for supplies. He had to drive around my little lake, across neighbors pastures and fields and finally would get to the county road.
I've got one small, very old picture of him in his "T". I think he is either stuck in some mud or one or more of the wooden spokes on one wheel may be broken. Hard to tell.
   / Cleaning debris from woods #19
Hi Don, I'm right nearby you and had a similar problem on my 19 acres (now sold down to 10 ac). First of all, don't even try to do this work in the summer time, its ridiculous trying to grab garbage up through living plants. Wait till October and it's much easier to see what you are doing. March/April is a good time for this type of work also.
My first thought is to gather the metal - it's worth money to recycle, after all. If you can gather up a good enough pile, get some cash back by trailering it to your closest recycler, or put up a craigslist ad for free metal scrap and it'll go quick.
Any glass, rubber or plastic is obviously garbage. I don't know a good way to gather it besides working by hand, tossing the crap into your loader bucket or other receptacle. Wood, you burn. Thats my 2 cents anyway.
   / Cleaning debris from woods #20
Burning has a couple of issues. In Michigan....at least my area, you need a burn permit. And it is dry now. If the fire gets away from you, the DNR will be there and expect a fine. If the local fire department shows up, there is a good chance they will charge you for their work as well
My neighbor just had a sizeble hunting camp he needed to get rid of. Called in an excavator to dig a hole and they buried it. They built a bit of a mound up to address any future settling. Depending on your soil and amount of junk, you may be able to use your FEL but the excavator will get deeper quicker and no chance of damaging your tires.
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
2006 Dodge Ram 1500 (A56858)
2006 Dodge Ram...
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
JOHNSON OUTBOARD MOTOR (A58374)
JOHNSON OUTBOARD...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
POLY BARREL & WELL TANK (A58374)
POLY BARREL & WELL...
