Cleaning a Mower Deck
/ Cleaning a Mower Deck #11
I agree 100% with Jinman. I leave the top belt covers off (risk tossing a belt off once in awhile when a stick flips in there) and keep this area clean and dry. Grass and debris gets under there with the covers on, and holds moisture (rain or water when washing the tractor) for rust to begin.
For under the deck, avoid if possible, mowing when the grass is wet. Also, I clean after mowing with water hose. As well, I mow up the sticks in the lawn to let them help keep the underside of the deck clean. Fall mowing and collection of dry leaves usually gives the underside of the deck a good shine if not caked with wet grass.
/ Cleaning a Mower Deck #12
Helps if you park your tractor inside too. The grass will dry off and is less likely to cause rusting it stays wet longer when you park on dirt
Old Wanker
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
TEREX RL4 LIGHT PLANT (A60736)
TEREX RL4 LIGHT...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Volvo EC220EL (A60462)
