Clean Vaaljapie Radiator
   / Clean Vaaljapie Radiator #1
Willsk
Harare
Massey Ferguson
I have checked my radiator and giving out some rusty water , how best can i clean it. Any suggestion will help
   / Clean Vaaljapie Radiator #2
First off, thanks for making me look up your tractor and town, both of which I had not heard of before.
The best way would be to flush the cooling system after you drain out the existing coolant. If you have petcocks on the radiator and block, you can drain that way.
   / Clean Vaaljapie Radiator #3
I would flush the radiator and block with garden hose pressure. Run water in through one line until it's clean coming out the other. Now flush it the other direction. You can repeat this a couple times if needed. Put it back together and fill with distilled water. Run until warm to be sure it's fully circulated. Drain. This will eliminate most minerals in water left from your hose flush. It won't hurt to even do the distilled water thing again. When done flushing fill with a 50/50 mix of anti freeze and distilled water.
2012 TCS CABLE, INC. GENERATOR (INOPERABLE) (A55745)
2012 TCS CABLE...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2016 Ford Explorer AWD Sedan (A55853)
2016 Ford Explorer...
