Clean new steel with ___ before painting?
   / Clean new steel with ___ before painting? #1
beppington
Elite Member
of my
Here
I bought two steel square tubes from metalsdepot.com, & it arrived with a coating of oil/ grease, I guess to keep it from rusting. I guess this is typical since the steel pieces at Home Depot all seem to be oily, too.
What should I use to clean that off before painting?
Any ol' degreaser, or ___?
Thank you
   / Clean new steel with ___ before painting? #2
Thank you
Laquer thinner should do it. If it is a high quality paint job then go to an auto paint shop, even NAPA should have it, and ask for a "metal prep".
   / Clean new steel with ___ before painting? #3
Degreaser is fine for getting off the oil, but you need to put some texture to the steel prior to painting. Preferably this is with a grit blasting, but a good stiff power brushing will work also. Painting onto smooth steel surfaces doesnt give the paint anything to latch onto, therefore when it gets a little chip, large areas pop off. If you power brush, you will need to degrease before and after the brushing to do it right. I would use a commercial degreaser with a power washer then use a power brush to put the texture on it followed by a wipe down with acetone or other solvent type cleaner. Put on a good steel primer (inorganic zinc or zinc chromate is best) followed by your top coat color of your choice. You will have a painted surface that will stay with you for years.
   / Clean new steel with ___ before painting? #4
laquer thinner will do it, BUT its one of the most volitile (read flamable, explosive, etc) degreasers out there....
   / Clean new steel with ___ before painting? #5
I always use a 36-grit sanding pad on a 4 1/2 inch grinder for cleanup after welding on anything I build.
   / Clean new steel with ___ before painting? #6
I've use mineral spirits to clean off the metal prior to painting.
   / Clean new steel with ___ before painting? #7
Gas is the cheapest. Gas is the most dangerous. Gas is the cheapest. Gas is the most dangerous. :thumbsup:
   / Clean new steel with ___ before painting? #9
Gas leaves a residue
   / Clean new steel with ___ before painting? #10
But it'll cut through the heavy stuff to where your lighter degreaser will suffice.
But I get your point. :)
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
53ft trailer Vin IUY VS2532 7M0152 01 VS2RA (A51694)
53ft trailer Vin...
