Backhoe classic JD 500C BACKHOE
/ classic JD 500C BACKHOE #1
jd500c
Gardom Lake, British Columbia
1973 John Deere 500c Backhoe
Hi, just new to this forum; from the posts I've seen, you all sound like a wise bunch.
I bought this classic 500c backhoe, she runs excellent but from what I can tell the engine is a bit of an oddball and I was hoping for any and all knowledge about any quirks or things to be aware of and also any history of thoughts on quality. It's a 4-270 engine, a waterloo from what I have read, with factory consol activated (solenoid) ether injection ( I use a inline heater), apparently has a counterbalance shaft for vibration (I bought the service manual).
And information would be appreciated. Thanks!
/ classic JD 500C BACKHOE #2
:welcome: to TBN
With what you have, and know now, you'll be answering questions soon.. :D
/ classic JD 500C BACKHOE #3
:welcome:
To the forum from Alabama.
/ classic JD 500C BACKHOE #4
:welcome:
Actually the engine has a counter balance box with several gears & 2 shafts in it.:
/ classic JD 500C BACKHOE #5
That is a BIG HEAVY old back hoe. I helped a neighbor R & R a bucket cylinder to replace the seals. His is an open version, not a cabbed.
/ classic JD 500C BACKHOE #6
The 270 cu in engine is the same one used in ag 3020 row crop tractors. It is a good solid reliable engine. It has wet sleeves, so easily rebuilt. As you mentioned, it has the counter-balancing unit bolted on the bottom of the block in the oil pan. The engine is a smaller version of the six cylinder 404 cu in engine used in many models and horsepower ranges in ag models. Same bore and stroke. Blocks and cylinder heads for the 4 cylinder version are a little scarce since they weren't used in many models.
Thanks for the welcomes.
Yes Zebrafive a heavy beast over 17,000 pounds with full cab.
Thanks txJim, I oversimplified, it's quite the balance box.
I look forward to making it a good looker, not just a good runner ;) plan on classic green in stead of the industrial yellow with two super sweet 70's style angled yellow stripes on either side to suit it's 73' vintage.
I siped my r4 industrial tires with a utility knife, 8 cuts per lug, still opening up but no longer have to sand my 1000' hill of a driveway when going back up to the house after pushing the snow down! Chains need a spacer, and with a 14 lug setup, that's not so easy.
Any strengths or weaknesses with this motor? Any opinion at all or common improvements?
Thanks fellas!
Thanks jd110, so she has a good powerplant, that's good. It's setup for ether from the factory, so it must be fairly robust I figured. Thanks for the response!
2005 John Deere 225CLE Hydraulic Excavator (A66734)
2005 John Deere...
2014 JCB 190T SKID STEER (A65056)
2014 JCB 190T SKID...
CAT 980C GP Bucket (A68134)
CAT 980C GP Bucket...
ZINGER BY CROSSROADS BUMPER PULL CAMPER (A67714)
ZINGER BY...
2020 FORD F-350 (A67714)
2020 FORD F-350...
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
