class III Oil Filter
   / class III Oil Filter #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
Is anyone using Wix or Napa ? So far only option I see is for dealer(New Holland oil filter)If so whats the part number?
   / class III Oil Filter #2
Wix # is 51056............it should be a direct cross to NAPA as wix makes their filters.......TOM
   / class III Oil Filter #3
</font><font color="blue" class="small">( Wix # is 51056............it should be a direct cross to NAPA as wix makes their filters.......TOM )</font>
Just wondering. Do all the Boomers take the same oil filter?
   / class III Oil Filter #4
I have two tractors at two different properties.........A TC33D and a TC40D.............The oil filters are the same..........I can't say for the smaller boomers...........Maybe someone else knows ? Just a FYI..........The NH oil filter was $10.44 and the wix was $9.64 at napa...........I've bought both.......The NH dealer is closer to my home property and NAPA is closer to my other place.........TOM
   / class III Oil Filter #5
The TC35 is the only boomer that takes a different oil filter than the one used on the rest. The one being mentioned is bigger around than the proper one for the TC35. The larger one will not fit because it rubs on the frame the New Holland part number for the TC35 is sba140517020
   / class III Oil Filter #6
Give a Ford/Motorcraft FL-300 (or anything equivalent) a try.
   / class III Oil Filter #7
I dont think that would be a good idea since we sell NH tractors and promote the use of original equipment parts. /forums/images/graemlins/smile.gif
   / class III Oil Filter #8
Yep.. there is a bolt head that prevents the bigger(cheaper cost) filter from fitting. I think it's from the loader bracket mount? When I went to the NH parts dept.(in 2000) to get an oil filter.. they had given me the larger one first. I told them that the filter seemed larger.. they said that's what the computer display showed as the replacement. An hour later I was there to return it.. had to pay a couple $ more for the smaller one.
   / class III Oil Filter #9
<font color="blue"> I can't say for the smaller boomers...........Maybe someone else knows ? </font>
The Class II Boomers take the Wix 51056 as well.
   / class III Oil Filter #10
Checked that bolt this weekend.. it's a bolt head that fastens the engine to the transmission.
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
