Class II Front Axle Jacking Points
   / Class II Front Axle Jacking Points #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
I'm in the midst of performing the 300 hour service on my TC25D and one of the tasks is to replace the front axle oil, both the differential and the reduction gear case oil. While draining the oil is easy, it looks like the only way the reduction gear case oil can be refilled is by removing the front wheels.
Where is it safe to jack the front of the tractor up and place jack stands under it? At the axle ends? Under the differential? I can get the front end off the ground with the FEL, but still need to know where it's safe (wont damage the tractor) to place two jack stands?
   / Class II Front Axle Jacking Points #2
I guess what I would do is raise the front end with your loader and then put blocks under the axles. Let tractor rest on your blocks. This way you have both wheels in the air at the same time and you don't have to worry about the one side raising up on you as you jack up.
murph
Thanks, murph, that's what I ended up doing. Worked out well and I got all the fluids changed in the front axle this afternoon.
   / Class II Front Axle Jacking Points #4
NO problem, running a jack is manual labor!!! We got tractor to eliminate manual labor /forums/images/graemlins/grin.gif
Murph
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
Chery 2 Post Car Lift (A50121)
Chery 2 Post Car...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2001 MACK RD688S (A52472)
2001 MACK RD688S...
