Forks Clamp on Pallet Forks
   / Clamp on Pallet Forks #11
The stabilizer bar has sleeves on both sides that slide over the forks. The width is adjustable. You are correct, the forks are made with a 2"x4" tube steel. I don't see why it wouldn't be possible to drill out a hole to accept a trailer ball. You would have to use your best judgement upon receipt of the forks.
Thanks for the inquiry!!! Have a great day!
   / Clamp on Pallet Forks #12
Thanks for the reply.
   / Clamp on Pallet Forks #13
I went ahead and ordered a set of the forks with the stabilizer bar. Looks like a nice product.
   / Clamp on Pallet Forks #14
Looking also at something like this for some light duty work. Moving some brush piles, maybe some attachments if I get them on pallets
How beneficial are the stabilizers? +50% to the cost is quite a lot if they are not really needed but for more HD uses.
   / Clamp on Pallet Forks #15
I bought the exact same set last year and they are IMHO a great buy...
I did cut some 1/2 thick square stock 2x2 so as not to bend my bucket...
They are an excellent value and much lower cost option versus the skid steer type...
You can load brush and logs very effectively if you put standards in the vertical holders located at the back of the forks..
   / Clamp on Pallet Forks #16
Maybe I'm too rough with mine but I have been trying to move brush piles that have a lot of dirt in them.
Even when tight, and with the stabilizer, the forks will move. They may both turn in a direction so the forks are not pointing straight out of the FEL.
If the situation is perfect then it works ok for me. If i have a big pile then I do have to work it quite a bit to get the forks to stay straight.
I'm wondering if I can fab up some other sort of solution to keep them straight. Maybe a stabilizer bar going to the edges of the FEL or something.
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
198367 (A51243)
198367 (A51243)
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
