Loader clamp on forks
   / clamp on forks #12
It would depend on if you mean the type that clamp on to the bottom lip of the bucket OR the kind that clamp and hang from the top lip of the bucket. Since I have the kind that clamp on the top lip of the bucket I can comment on those, because I cannot see how the other type could work. Since the forks are "L" shaped, the short leg of the "L" is attached to the clamp at the top lip of the bucket, and the right angle of the "L" is at and just below the bottom lip of the bucket, protruding forward to lift whatever you're moving. That part should be able to fit between the teeth on the lower lip. Check out the forks at BXPanded.com. Harry is great to work with, and can help you further.:thumbsup:
   / clamp on forks #13
Are clamp on forks still suitable on loader buckets fitted with tooth bar teeth? Anyone care to comment?
I have a land pride set. 1,000lb capacity rating. They do work with my tooth bar. As others have stated they are "OK" for certain things. Have to be careful with heavy loads way out on the end. While a 1,000lbs might seem like a decent weight rating, gotta keep in mind the possibility the bottom of the bucket bending.
   / clamp on forks #14
Spend the extra money and get a quick attach set. The problem with the clap on forks is that they reduce a lot of the lifting power of the loader by moving the weight further forward. Secondly the bucket blocks your view, not that the QA system allows a great view of the forks.
I have a 3500 lb set for my full size backhoe and while they work they are far from ideal. It doesn't have a QA system so the clamp on style forks were a cheap option. They do the job and because the lift capacity of my BH is a lot more than a cut lack of lifting force hasn't been too much of an issue. But I've already decided to just spend the extra money and get the QA style for my Kubota.
   / clamp on forks #15
I know that no one likes to do this, but the search function can be your friend. This is a subject that has been posted upon thousands of times over the years.
I usually try a search first for a question that I may have. If I don't find answers specific enough, then I post a new topic.
However, it is really easy to miss something that someone else may have posted about your specific question because there's such a volume of information here.
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
KUBOTA RCK54P-400Z MOWER DECK (A57192)
KUBOTA RCK54P-400Z...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
Metal Sunfower Lawn Art (A55853)
Metal Sunfower...
UNUSED FUTURE FT-PDQ 40" LAND LEVELER (A57193)
UNUSED FUTURE...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
