CLACK noise from left rear wheel?
   / CLACK noise from left rear wheel? #1
Raincoast
Powell River BC
Kioti ds4510 / kb2485 backhoe / KL401 loader
Hi folks;
My DS4510 has (occasionally) made a loud single clack sound that seems to be coming from the left rear wheel. (Though it is hard to say, for sure)
The tractor is 5 months old & in the 75 hours since new, it's happened maybe a dozen times.
My kioti dealer hasn't been helpful. Before I start making an issue out of this I wanted to check with more experienced folks on the forum.
Anyone heard of this before?
The tractor functions are all normal. In all gears in two & four wheel drive.
The noise seems to happen only once. It makes no difference operationally when it happens.
   / CLACK noise from left rear wheel? #2
Do you ever use the diff-lock? Sometimes they're not real quick to disengage and I've seen some older units of various makes that will "pop" out and make a somewhat disturbing sound.
   / CLACK noise from left rear wheel? #3
turn steering wheel hard right and goose it, then go straight for 15' then hard left and straight that should disengage the locking diff.
   / CLACK noise from left rear wheel? #4
Can also just drive slowly forward and alternate the right and left braking some.
Interesting... I'll give that a try & pay attention whenever I use the diff lock.
This is very reassuring. Thanks guys!
   / CLACK noise from left rear wheel? #6
My CK makes a very disturbing pop when coming out of the diff lock. I think it's just the differential unlocking, and nothing to worry about. If your noise only happens every once in a while and doesn't get worse, I'd not worry, there's a lot going on down there that can make noise.
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56435)
2023 Top Air ATV...
2002 Ingersoll Rand P185WIR Towable Air Compressor (A55851)
2002 Ingersoll...
2019 Bobcat E32i Mini Excavator (A55851)
2019 Bobcat E32i...
2022 Case SV280B (A53317)
2022 Case SV280B...
DOOSAN DL300-3 HYD 4N1 114" BUCKET (A57192)
DOOSAN DL300-3 HYD...
