Oil & Fuel CK3710 HST Steering Fluid
   / CK3710 HST Steering Fluid #1
GisborneSouth
Gisborne South, Vic
Kioti CK3710
Greetings All from Gisborne Australia!
I have a Kioti CK3710 HST. The right hand steering drain plug has vibrated loose and is lost in the paddock. What fluid and quantity do I need to put in?
Thanks!
   / CK3710 HST Steering Fluid #2
I'm guessing it's like the CK3510/4010 here in the states.
Are you talking about the lower axle drain plugs, down by the tire?
If so you can use the same hydraulic oil as in the transmission, or 90wt gear oil.
BTI
Thanks BTI! I think the CK3710H-AUS is the same as the CK3510 in the US. It is the lower axle drain plugs by the tyre. It is an M10 bolt with a 1.25 pitch. It vibrated out and the oil went with it. I will get some 90wt gear oil. I put in iso68 to get by and will drop that out..
Thanks again for your help!
   / CK3710 HST Steering Fluid #4
To answer the initial question, there should be a sight glass (for fill level) on the back side of the left front axle. The total capacity is 4-5 quarts. Check the sight glass on a level surface and allow PLENTY of time for the oil to level out.
Utility Cart (A59228)
Sedan (A59231)
Sedan (A59231)
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
DEVELON DL250-7 WHEEL LOADER (A59823)
DEVELON DL250-7...
Sedan (A59231)
Sedan (A59231)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
