CK35H Fuel tank collapsed
   / CK35H Fuel tank collapsed #1
zarashep
Kioti CK35
The plastic fuel tank on my Kioti CK35 HST has collapsed, The tank top has become concave and it holds about half of the fuel it used to. The good news is that it does not leak. Has anyone heard of this? Can I pressurize it to pop it back to its original shape, or is a new tank in order?
   / CK35H Fuel tank collapsed #2
My CK30 HST has a vented fuel cap. Is the fuel cap original? Check the bottom side of the fuel cap to see if it's become blocked. Does the tractor run normally or does it act like it's starving for fuel?
Don
   / CK35H Fuel tank collapsed #3
Plastic fuel tank? When did this start? :confused:
My 2006 CK20HST has a metal tank.
The tractor runs fine. I lost the original cap but replaced it with a Kioti cap that I bought from the Kioti dealer.
It started about a week ago and it got much worse today. It looks like a grey ABS-type material but I will scratch it with a knife tomorrow to be sure.
   / CK35H Fuel tank collapsed #6
Any un-vented tank can be collapsed easily by even a small pump. Regardless whether the tank is plastic or steel, a fuel lift pump or an injection pump is quite capable of collapsing it if it's not vented. I'll guess the new cap is not properly vented.
Re-expanding by inflating is not so easy and potentially very unsafe. You may have to replace it, or live with reduced fuel capacity.
   / CK35H Fuel tank collapsed #7
My 2004 CK30hst has a gray plastic tank just in front of the firewall and behind the engine. It's never collapsed. The plastic is pretty heavy/thick. If you lost about half of the capacity, (4gallons), it must be really crushed down. I'd imagine the plastic wouldn't like coming back to it's original shape without cracking somewhere. I also think your cap isn't venting.
   / CK35H Fuel tank collapsed #8
Yep, not venting. My '08 DK40 has a plastic tank.
   / CK35H Fuel tank collapsed #9
Drain it.
Clean it.
Block off exit/input lines.
Gently apply positive pressure.
Fix vent in cap.
Reconnect lines.
Refill tank.
JOHN DEERE 520 SHREDDER LOT NUMBER 253 (A53084)
JOHN DEERE 520...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2018 JOHN DEERE 672 GP (A52472)
2018 JOHN DEERE...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
