ck3510se white exhaust smoke when cold, only started after last oil change
   / ck3510se white exhaust smoke when cold, only started after last oil change #1
NYCheese
Near Binghamton NY
Kioti CK3510se hst TLB
My first 2 oil changes were done using a Cub Cadet branded diesel oil (dealer is also a Cub Cadet dealer, and he said it exceeded Kioti's requirements).
Most recent oil change I had to switch, because he was out of stock, and said it was going to be a while before he got more. He recommended the Rotella T4, and after doing some research online, that's what I went with.
I've put about 30hrs on since then, and I've noticed that when the tractor is cold, I'm getting a fair bit of white exhaust (that smells like unburnt fuel), that I never had last winter with the other oil. It goes away when the engine warms up, so it seems pretty normal to me...just wondering if I should be concerned at all.
   / ck3510se white exhaust smoke when cold, only started after last oil change #2
I believe a small amount of white smoke indicates unburnt fuel when the engine is cold and is perfectly normal. I don't know what constitutes "a fair bit" but if it disappears when the engine warms your should be fine.
   / ck3510se white exhaust smoke when cold, only started after last oil change #3
condensation steaming off is also a common cold startup white smoke signature. Also normal.
Thanks for confirming normal for me. I said "fair bit", because it's definitely less than what I would call "a lot", but it's slightly more than I would call "a little". It does go away entirely once the engine is up to temp.
It definitely has some unburnt fuel in it, you can smell it clearly. I was pretty sure it's normal for cold weather....just wanted to confirm, since I did swap oil brands.
   / ck3510se white exhaust smoke when cold, only started after last oil change #6
All diesel's 'huff' a bit when cold, especially when it's around or below freezing. Nature of the engine.
   / ck3510se white exhaust smoke when cold, only started after last oil change #7
I suspect the ambient air temperature is lower or the cetane rating of your fuel is lower than what you used last winter.
Lube oil won’t cause white smoke.
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
