CK3510SE HC hydrostatic drive issue
/ CK3510SE HC hydrostatic drive issue #1
Diesel2697
Weedsport, NY
Simplicity Legacy XL Diesel
Ok so I have had this tractor since August 2020 and haven’t had any issues. It now has 97 hours on it and this morning it started acting strange. (It had the service done at 40 hours by the dealer, complete fluid and filter change) It was 9F this morning, I started it and let it run for about 15 minutes while the horses ate then pulled it into the barn to clean barn. I left it running the whole time so total about 45 minutes. I backed out to go dump the first load and it was going good until I came to the hill in our yard. **** thing came to a complete stop and wouldn’t move like the transmission was slipping. If I put it into 4x4 or step on the diff lock it moves fine. Did this multiple times every time it got someplace that wasn’t flat. Could this just be because the fluid was cold? Or could something be wrong inside the rear end. Thanks for any input.
/ CK3510SE HC hydrostatic drive issue #2
I think what you experienced is normal for very cold weather. I have only seen that type of tractor behavior on my CK4010 when I have cold HST fluids (below 10F) or my parking brake is on. Warming the tractor is good for the engine, but does very little to warming the HST fluids. I would keep the 4x4 on for most the cold winter and make sure you have anti-gel additive in your diesel fuel. If it's cold enough to thicken your HST fluid, it's doing it to your diesel fuel as well.
/ CK3510SE HC hydrostatic drive issue #3
I would think even HST has its limits in very cold weather.
First call should have been to your dealer. Its under warranty
/ CK3510SE HC hydrostatic drive issue #4
Sounds like a differential problem.
If it was a problem with the hydrostat, it wouldn't move after the diff is locked or put in 4wd.
This is just a speculation: Given the situation that you were approaching the pile, you quite likely raised your loader. This may have taken more oil out of the sump and the hydrostat starved out. By the time you applied the diff lock or put it in 4wd, the loader was up and hydro worked again.
Yea if they were open on Sunday they would have gotten a call. They are going to get one first thing tomorrow, Monday, morning.
That’s exactly what I’m thinking. I used it for 3-4 hours yesterday, Saturday, snowblowing and it never gave any trouble. It was about 10 degrees warmer outside also, around 20f.
/ CK3510SE HC hydrostatic drive issue #8
This makes me think a rim is spinning in the tire. Tires loaded? What pressure is in the rears?
/ CK3510SE HC hydrostatic drive issue #9
Certainly worth looking into.
Wouldn't be the first time I've heard of that happening
Oh boy you may be on to something. Yes the tires are loaded with Rim Guard. Tire pressure?? That’s a good question, I haven’t checked them in a while. I did notice some dark liquid on the barn floor under what would have been the left rear tire, the one that was slipping. I stuck fingers in it and smelled it thinking it was some sort of oil. It didn’t smell like anything so I figured possibly manure water because it’s wet where our pile is. Now after what you said I’m betting it was the Rim Guard and I am slipping the rim inside the tire. Thank you very much!
/ CK3510SE HC hydrostatic drive issue #11
Hopefully that gets you going. It happens when air pressure gets low with loaded tires. Back it up with about 15 PSI and you should be good to go.
/ CK3510SE HC hydrostatic drive issue #12
Rim guard has a definite odor, like a sweet manure is the best I can describe it and once you smell it, your not going to forget it.
/ CK3510SE HC hydrostatic drive issue #13
I had the same idea after I postet the "differential issue".
/ CK3510SE HC hydrostatic drive issue #14
Hopefully that is the problem. It is one of the more over looked possibilities when troubleshooting a problem such as this. We tend to think the worst but it seldom is. I have learned over the years to check all the simple stuff first then go deeper if needed.
/ CK3510SE HC hydrostatic drive issue #15
You're right. Simple is sometimes too complicated.
I do believe that was the problem. I made it home last night and checked the tire pressure. It didn’t even register on my gauge. Best part is they must have filled the thing with Rim Guard because it kept coming out every time I stopped putting air in. I had the valve stem top center and could only get the filler to read right after I put air in. The right side was low also but gauge would read without issue. Ended up putting 20psi in the problem tire and matched it on the right. Thanks for the info.
I was able to smell it last night outside. You are 100% correct on it’s odor. Must be because we were cleaning barn it just matched the smell the other day.
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
Hydraulic Concrete Breaker Excavator Attachment (A59228)
Hydraulic Concrete...
UNUSED KJ K2223-23' X 22' DOUBLE GARAGE METAL SHED (A60432)
UNUSED KJ...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
2011 KUBOTA U25 SUPER SERIES EXCAVATOR (A60429)
2011 KUBOTA U25...
