Tires CK3510 Front Rims
   / CK3510 Front Rims #1
MailManX
2021 Kioti CK3510SE HST
I bent a front rim. I straightened it, I hope, but I want to buy a spare just in case.
So far, all of the replacements I have found for an 8x15 rim have a center hole of 4.62 inches. My imperfect measurement of the center hole in my Kioti front rims is just under 3.5 inches.
Where can I buy these, besides the dealer, for a decent price?
Also, is there another brand of tractor that has the same size so I have more options?
   / CK3510 Front Rims #2
You always go to the dealer first!!! How else would know if a deal somewhere else with someone else….is a deal??
   / CK3510 Front Rims
The dealer is 2-1/2 hours from me.
Are you able to answer the question?
   / CK3510 Front Rims #4
I think kioti still makes bobcat tractors, you can try there. When I was trying to buy new wheels and tires I found out tractors are a lot different than cars, almost every manufacturer uses different center bore or bolt pattern.
   / CK3510 Front Rims #5
Yah his dealer is 2.5 hours away, and there may be long distance charges to call them for advice, so a wrong wheel sounds ok…🤷
   / CK3510 Front Rims
Sheesh. Attitude. (n)
Thank you to AaronD81 for a thoughtful answer.
I called the dealer. It was difficult. I think the guy was brand new. He spent a long time hemming and hawing. He asked if the size was 27x8.50-15. I told him that was the TIRE size. He seemed confused. He asked me the rim size. I gave it to him. He finally said, “This system I am looking at is kind of difficult. I will go ask my manager.”
Instead of getting on the phone with me, the manager was shouting from a distance to the newby. The newby finally said, “The rim is $213 but it is backordered.” I asked if he knew for how long. He said he would call Kioti tomorrow and find out then call me. I really appreciated that.
I asked if he’d verify a few things before I hung up. He told me the Kioti part number is 222013W. I asked if he could tell me the pilot hole diameter. He did not know what that was. I explained that it was the large center hole inside the bolt hole ring. He said that the diagram did not say. I’m not surprised. Kioti documentation is not the best. We ended the call.
So, I have nothing against the dealer other than cost and wishing the parts adviser knew a bit more.
I’ll look into the Bobcat lead.
   / CK3510 Front Rims #7
You’re welcome. It’s too bad that you had a newbie on the phone, but that made two of you. See your statement My imperfect measurement of the center hole in my Kioti front rims is just under 3.5 inches
So now that you have some info such as cost and part number (not sure if I’d trust that # though?), try another dealer and maybe a Bobcat dealer as suggested by Aaron. Good luck
   / CK3510 Front Rims
Thank you very much! I will call them tomorrow.
6ft Wolverine Sweeper (A57454)
6ft Wolverine...
2017 JOHN DEERE 544K-II WHEEL LOADER (A52709)
2017 JOHN DEERE...
2136 (A58376)
2136 (A58376)
New/Unused Single Portable Toilet (A57453)
New/Unused Single...
2022 Deere 325G (A57148)
2022 Deere 325G...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
