ck35
rbike
I have a new ck35 about 3 weeks now with 20 hrs. The rev. , forward shifter is real hard to move. I thought it would loosen up by now. Any one else having same probles?
You called it a rev. , forward shifter
Not sure what it is you are talking about. The throttle lever by the steering wheel or the HST foot petal? :) I have not had problems with either on my 2 year old CK35 HST.
/ ck35
it's gear driven. it's the shuttle shifter. my foot cable did stick but I fixed it.
Check linkages and shafts where they enter the transmission housing and lubricate them well, it's been widely known to have shafts rust and corrode where they enter the housing, especially if they have been kept outside for periods of time.
Steve
/ ck35
it's a new tractor, both tractors i tried at the dealer were the same way. i was just wondering if anyone else had this problem.
I have a CK25,gear,and the shuttle shifter can be a bit of a pia,however after 550 hours,it seems to shift easier or maybe I am just getting more use to it.
It does seem to be one of those things that become second nature when you get used to it, but you wonder if something is not right. Every now and then I will be shifting and the lever just will not smoothly do what I want it to do. I have 430 hours now and it shifts ok but tight at times. Maybe I will look underneath to be sure all grease plugs are filled.
We had the same issue with our CK35. When the dealer popped by he lifted the rubber cover up and sprayed a lube into the linkage, worked it a couple times and voila!!! Nice and easy now.:thumbsup:
/ ck35
40 hours and it's got better. what cover did he removed?
The rubber sock where the rod goes into the dash. Spray lube and worked it back and forth a few times.
had the same prob its at the top by the steering i think it is 4 bolts lube under the rubber boot Don
/ ck35
the advice from bluepine worked thanks
Electric Concrete Mixer (A65579)
Electric Concrete...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
Kivel Quick Hitch Mini Skid Steer Attachment (A64553)
Kivel Quick Hitch...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
UTILI TOUGH 48" RAKE (A64277)
UTILI TOUGH 48"...
Club Car Electric Golf Cart (A65579)
Club Car Electric...
