ck35
   / ck35 #1
rbike
I have a new ck35 about 3 weeks now with 20 hrs. The rev. , forward shifter is real hard to move. I thought it would loosen up by now. Any one else having same probles?
   / ck35 #2
You called it a rev. , forward shifter
Not sure what it is you are talking about. The throttle lever by the steering wheel or the HST foot petal? :) I have not had problems with either on my 2 year old CK35 HST.
   / ck35
it's gear driven. it's the shuttle shifter. my foot cable did stick but I fixed it.
   / ck35 #5
Check linkages and shafts where they enter the transmission housing and lubricate them well, it's been widely known to have shafts rust and corrode where they enter the housing, especially if they have been kept outside for periods of time.
Steve
   / ck35
it's a new tractor, both tractors i tried at the dealer were the same way. i was just wondering if anyone else had this problem.
   / ck35 #7
I have a CK25,gear,and the shuttle shifter can be a bit of a pia,however after 550 hours,it seems to shift easier or maybe I am just getting more use to it.
   / ck35 #8
It does seem to be one of those things that become second nature when you get used to it, but you wonder if something is not right. Every now and then I will be shifting and the lever just will not smoothly do what I want it to do. I have 430 hours now and it shifts ok but tight at times. Maybe I will look underneath to be sure all grease plugs are filled.
   / ck35 #9
We had the same issue with our CK35. When the dealer popped by he lifted the rubber cover up and sprayed a lube into the linkage, worked it a couple times and voila!!! Nice and easy now.:thumbsup:
   / ck35
40 hours and it's got better. what cover did he removed?
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
71066 (A49346)
71066 (A49346)
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
John Deere 637 Disk (A50514)
John Deere 637...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
