Price Check CK35 HST price check and pump question
   / CK35 HST price check and pump question #1
BJN644
Maine
Kioti CK35 HST
Getting ready to make a move on a new tractor and stumbled across the free FEL deal on this great forum. Got a price of $18,600 + tax, good deal?
I wondered about how Kioti rates their hydraulic pumps. They only list one number, close to 13 gpm, no breakdown for power steering and impliment like other manufactures do. Do they truley have the highest pump flow in this size class and use all the flow for everything including power steering?
   / CK35 HST price check and pump question #2
I don't know if the free loader deal is still going on or not, I thought that it was for June only. But I had a price of $16,500 for a CK35 HST with loader, 2 rear remotes and a sun shade. :) But it was still more than I could really afford. :( Price can vary some due to dealer location. Good luck, they seem to be quite a machine to me.
   / CK35 HST price check and pump question #3
KIOTI has extended the CK35 Free Loader offer until the end of July, or until stocks are depleted. We have (2) CK35 HST Tractors left in stock.
   / CK35 HST price check and pump question #4
That prices seems very high to me.....I am unsure where you live, but at Brownies in Ohio CK35 Gear was 14,100.00 and the HST was about $900.00 more. This was with the "free" FEL. After I had chain hooks welded to the bucket, a set of rear remotes, industrial tires, and delivered...My prices was $15,XXX.
   / CK35 HST price check and pump question #5
If you're in an area around Ohio I'd strongly suggest looking Mr. Brown up @ Brownie's Tractor in Nellsonville, OH. If he has one in stock or can get you one you'll be doing yourself a huge favor. I'm biased of course and I'm sure the other dealers are good as well.
Good luck.
   / CK35 HST price check and pump question #6
Doesn't matter what part of the country you're in except maybe downtown NY or LA, that price stinks. I coulda bought one for less than that without the free loader deal. What I did buy had the free loader and was $5000 (yes I meant to type 3 zeros) less than that here in GA.
I'm pretty sure there's a separate pump for the power steering.
Dave
Since my first post I have found that my local dealer is not giving me a good price at all. As much as I would like to support my local business I found a couple of dealers who frequent this site that are willing to save me thousands and deliver the tractor hundreds of miles to me. With the money I'll be saving I can now buy a trailer to haul my new toy around with.
I still haven't got a good answer on the hydraulic pump yet.
   / CK35 HST price check and pump question #8
I'm pretty sure it is one pump, just under 13 gpm, that is shared between hydraulics and power steering. Somewhere between 7 and 8 gpm for hydraulics. This is on the Kioti website under specifications. But, I'm still afraid to go there due to the viruses.
   / CK35 HST price check and pump question #9
The KIOTI CK series tractors are all equiped with tandem gear hydraulic pumps. There are seperate pump chambers for the power steering and auxiliary hydraulics in the tractor. The power steering chamber provides 4.64gpm to the steering circuit, the second chamber provides 8.24 gpm to the auxiliary hydraulics, for a total hydraulic flow capacity of 12.88 gpm.
Tandem pumps are a better way to provide consisent flow to the steering circuit than the older priority valve systems, that tended to rob the auxiliary hydraulics for steering control.
Hope that helps.
Hope that helps.
Yes that helps very much, thanks.
So when someone tells me that Kioti has the highest pump flow rate in it's class (because they only list total flow of the two chambers combined) I am getting fed a line of BS. Not saying that there is anthing wrong with the published specs, just tell me the truth that Kioti is on par with other manufactures pump rates.
1998 FORD CRANE (A52472)
1998 FORD CRANE...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
