Ck35 Hst Headlights won't work
   / Ck35 Hst Headlights won't work #1
bbenyack
Johnstown, PA
Was in the woods this evening, went to leave and headlights wouldn't work on low beam. I switched to high and they worked. Switched back to low just to check again...nothing. Switched back to hi, they came on then went out. They flickered once when I first went to back out. Dash lights, tail lights and high beam indicator all are working. Checked wiring from headlights back as far as I can see, everything looked ok. There was a crimp mark on the harness where it goes over the firewall behind the engine but wires inside feel ok. I reached up to the headlight switch and moved all the connectors and wires and not even a flicker. Any ideas? head light switch gone? Only have about 250 hrs on machine.
   / Ck35 Hst Headlights won't work #2
More than likely if you pull the connector apart under the right side floorboard you will find one of the blades corroded.
BTI
Mystery solved, I think. Both headlights lamps were shattered. Was some condensation on the inside of the lens. Kind of weird the way they both went at the same time. Don't know what caused that. Guess I'll find out if I've got other problems when I get new bulbs.
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2014 Ford Escape SUV (A50324)
2014 Ford Escape...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
Ficklin 4500 Gravity Wagon (A50774)
Ficklin 4500...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
