CK35 H4 headlights to LEDs with cooling fans?
   / CK35 H4 headlights to LEDs with cooling fans? #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
I decided to go LEDs for H4 headlight bulb replacements and the ones I got actually have cooling fans built in the rear of them. IMG_20170607_143650.jpg
My concern is that now the rubber boot that protects the bulbs from moisture won't fit over them. IMG_20170607_143748.jpg
I could cut them but the fan end of my new bulbs will still be exposed. Anybody try a mod like this?
   / CK35 H4 headlights to LEDs with cooling fans? #2
I think you need to leave the back end of those LEDs open. Presumably, the fan is there for a reason. But in my experience, light reflected from the loader and brush guard make the factory headlights almost worthless. Flat-black paint (on backside of loader and brush guard) may help but a better solution is to mount lights on the ROPS or canopy.
   / CK35 H4 headlights to LEDs with cooling fans? #3
I wouldn't bother with LEDs that rely on tiny fans. The fan will clog with dirt and overheat the LED. Those same fans die all the time in server rooms - I can't believe someone would design that setup for on the road, let alone off-road. I have found versions that use heatsinks and no moving parts.
My ROPS, when raised, is about 2" higher than my garage so that's not an option.
I think if I cut them to wrap around the bulbs, the base will still allow air flow around the base and provide no less moisture resistance than without. I'll keep them snug with electricians tape. Better than not.
That's what I was thinking. I have little faith in these lasting any amount of time, hence my reluctance to cut the rubber boots. I've seen the ones with heatsink. They were actually more expensive. These do cast an impressive beam of light though.
   / CK35 H4 headlights to LEDs with cooling fans? #6
I have to fold my ROPs down on occasion too, so this is what I came up with. Those brackets don't wobble/vibrate or anything either, been like that for 3 years now and no troubles.
They are bright too
Wooden Sleigh (A50774)
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
(30) 9 Box Macro Bins (A50121)
(30) 9 Box Macro...
2006 Cat 963C Crawler Loader (RIDE AND DRIVE) (NICE) (A50774)
2006 Cat 963C...
