Dirt Moving CK35 Box scraper
/ CK35 Box scraper #1
dustinfox
New Hampshire
Kioti CK35 HST
Will my CK35HST pull a 6' box scraper? I am looking at the box scrapers at Tractor Supply Co. They have a 5' and a 6' both the same price ($599). 72" (six feet) would be good but I don't want to get something that my tractor will have trouble pulling. I need it for my 400' gravel driveway.
Thanks!
/ CK35 Box scraper #2
I have a 6 ft that I use with my CK35 HST. If I get it full of wet gravel it can be a bit tough to pull, have had to put the tractor into 4 WD. You should really get the 5 ft for it. Reason I got the 6 ft was it was well priced used.:)
/ CK35 Box scraper #3
I understand Mousefield's reason for the 5ft but you could adjust so you don't take as big a bite and use the 4wd when needed. If you have R4 tires, the outside width of the R4s is 63". I like to be wider than my tracks. Good luck on choosing.
/ CK35 Box scraper
Thanks... I have ag tires... I'll have to go measure the width. Makes sense to be wider than the tires!
/ CK35 Box scraper
Tractor Supply is having a grand opening 10% off sale. The 5 or 6 foot box scraper are the same price so I am going up today to get the 6 footer. Hope it works!
/ CK35 Box scraper #6
I have a DK 35 gear model. A little bigger in frame size but the same HP as the CK 35.
It will pull a 6' box blade heaping full with no problem.
/ CK35 Box scraper #7
I have a DK35HST with a 60" TSC box blade. Full of slop in the mud it is no match for the tractor. I personally would go 72" if i had to do over again. "Go BIG or go home!" is my motto. . . . Good Luck, John
JOHN DEERE D110 RIDING LAWN MOWER (A62131)
JOHN DEERE D110...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63118)
2021 Unverferth...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
UNUSED IRANCH WROUGHT IRON SITE FENCE (A62131)
UNUSED IRANCH...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
2016 NISSAN JUKE (A62130)
2016 NISSAN JUKE...
