CK30HST Starting dash lights flicker
   / CK30HST Starting dash lights flicker
I'll give it a try as soon as I get to my tractor's den.
It's really a mess out there right now after the several feet of snow we got last Friday.
To make matters worse, it started raining on Monday and started a quick melt.
   / CK30HST Starting dash lights flicker #12
We are having the same messy weather here. Snow, melt rain, freezing rain, warm, melt, cold, freeze up, repeat! LOL
   / CK30HST Starting dash lights flicker #13
I had checked when I first had this problem. Will go over everything again. Intermittent problems are such a pita!
A visual check won't help, you have to remove the cables and clean both terminal and post. These tractors hate even a slightly dirty battery connection.
   / CK30HST Starting dash lights flicker #14
Correct.
He also needs to remove the ground cable were it bolts to the frame and clean the connections.
Just wanted to say that I am not ignoring all your fine advice, I just have not had the chance to do all the suggested checks. Will try this weekend.
While I check the connections, what product (available in Canada) does anyone recomment to use to keep the connections clean and corrosion free?
I keep my Kioti in an unheated covered separate storage area along with all the implements.
   / CK30HST Starting dash lights flicker #16
Dielectric grease, available in any auto store, or battery terminal spray; spray it on after through cleaning with emery cloth or sandpaper.
Been over 4 months since I followed the advice given and after tightening the ground connection, have never had the problem again. Many thanks to all!
   / CK30HST Starting dash lights flicker #18
Great news! You're welcome, too.
2017 Ford F-550 (A55973)
2017 Ford F-550...
2019 KENWORTH T800 KILL TRUCK (A58214)
2019 KENWORTH T800...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
