CK30HST modified grill guard
/ CK30HST modified grill guard #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
I added to the factory grill guard with some 1/8th in perforated steel plate, ground all the welds and primered, painted Chevy orange and clearcoated.
The metal angles with the contour down low- it was cut/ welded and ground there to have a "bodyline"---I dont have a sheet metal bender.
I dont forrage brush so I didn't have the need to cover up the headlghts.
The factory threw me a curve---ONE of the supplied nuts was LEFT HAND THREAD!!! The bolt was a little wierd on the end threads so it took me a spell to figure this out, I was filing threads thinking I'd get a mesh...lol
Found a good nut in the wee town of Packwood, WA
Thanks to RedRocker for measurements.
/ CK30HST modified grill guard #3
what color and brand of paint? looks very nice
/ CK30HST modified grill guard #4
You did a great job. Lights would be a lot less expensive to replace than the stuff you did protect! Very smooth piece.
John
/ CK30HST modified grill guard #5
So were those dimensions I posted usefull, or did you have to measure your own?
</font><font color="blueclass=small">( what color and brand of paint? looks very nice )</font>
It is DupliColor from the local Schucks Chevy orange---not the real hi temp exhaust stuff but just engine color--can get the sku#off the can from work if u want
I also hang up my stuff to paint but before that, prep it like autobody---start with coarse and work to progressivley finer grit paper. Prime with a build primer which is available in a rattle can, sand that w/ 320. Wipe with pre paint grease remover quart can from autobody supply to avoid fisheyes. Use a tackcloth to remove lint, etc. But thats me and I understand "its just a tractor..."
If you paint a turd-- you just get a painted turd...it's all in the prep. /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( So were those dimensions I posted usefull, or did you have to measure your own? )</font>
I used your specs. thanks!!!
Got a new plasma cutter---now I'm Mr. Metalcrafter...lol
/ CK30HST modified grill guard #9
I'm lusting for a CNC plasma cutter, maybe someday.
</font><font color="blue" class="small">( I'm lusting for a CNC plasma cutter, maybe someday. )</font>
sounds like a ton of cash!
I'd need more real estate to house all the equipment.
Prime 283 (A64126)
Prime 283 (A64126)
John Deere 3025E (A64126)
John Deere 3025E...
Husqvarna MZ61 Zero Turn Mower (A66285)
Husqvarna MZ61...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 4,000lb. Crane Service Truck (A61573)
2017 Ford F-550...
2013 Kobelco SK26LC (A64126)
2013 Kobelco...
Here are some similar links:
