CK30hst 4WD knob replacement needed
   / CK30hst 4WD knob replacement needed #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
The 4WD knob is PLASTIC and stripped. it no longer stays on the threaded rod.
Has anyone done a fix for this?
What thread is the rod?
THanks.
Mike
   / CK30hst 4WD knob replacement needed #3
I packed mine full of 2 part epoxy putty and threaded it on before it set. It's been holding up pretty good ever since. Crappy design by Kioti. Should have metal insert.
Thanks all. Was thinking of the epoxy route, also getting a threaded rod connector and a short piece of rod, then the epoxied knob...
Mike
   / CK30hst 4WD knob replacement needed #5
Just the epoxy alone might be better. Adding the rod connector may set the knob out far enough to catch your foot getting on & off. Depends on your shoe size.
agree, i just used GOOP on it as is.
thanks
mike
   / CK30hst 4WD knob replacement needed #7
I just left the knob off fo mine. Make sure to lube the linkage and shafts thoroughly, I found that helped allot to make it easier to move the knob.
   / CK30hst 4WD knob replacement needed #8
I had the same problem and just used a hacksaw to cut back the plastic knob about 1/2 inch where it threads in and it reattached.... really tight now.
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
AUCTION STARTS HERE @ 9AM (A52708)
AUCTION STARTS...
1408 (A57192)
1408 (A57192)
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
