ck30 with back-hoe good/bad
/ ck30 with back-hoe good/bad #21
</font><font color="blue" class="small">( I also have a ck30hst with the 2375 hoe. The valve body was replaced in mine within a week. It would leak to the ground in less that 30 minutes. )</font>
Mine seems to "leak down" very quickly. It still works just fine though.. Is it a problem?
/ ck30 with back-hoe good/bad #22
I'm no expert on the subject but when mine was at it's worst it was very irritating. I would have to stop and raise the main boom to keep the bucket off of the ground unless I had the pin in the boom to stop it and then that got so it was almost impossible to put in until I got a smaller diameter pin. I am not sure how fast yours leaks off but if is like mine was you would not doubt want to have it looked at. Mine still leaks off and seems to be faster now than when the valve was replaced but nothing like it was.
/ ck30 with back-hoe good/bad #23
Talked to Travis Group about a Kioti BH yesterday, he suggested getting one with a PTO driven hydraulic pump instead of using the tractor's hydraulics.
Sounds good to me, anyone done that?
Mike
/ ck30 with back-hoe good/bad #24
</font><font color="blue" class="small">( Talked to Travis Group about a Kioti BH yesterday, he suggested getting one with a PTO driven hydraulic pump instead of using the tractor's hydraulics.
)</font>
I believe I've read several posts from members who use a PTO pump instead of the tractor hydraulics. They were all happy with the set up, and it maintained the fluid in the backhoe without contaminating the rest of the tractor's system. Not a bad way to go in my estimate.
John
/ ck30 with back-hoe good/bad #25
The independent PTO driven BH will add a good bit of weight. The pump itself plus the big ol' fluid reservoir. Also the tractor's system is run through a cooler to keep the fluid temperature under control.
I like the idea of separate systems though to minimize cross contamination. Don't think I would consider a Kioti BH with such alternatives as the Woods out there.
/ ck30 with back-hoe good/bad #26
Thanks guys. I do want to go with Kioti, I've had no trouble so far with the ck30hst, and i do like the color!
Mike
/ ck30 with back-hoe good/bad #27
Tractor hydraulics will operate it much more quickly and at pretty-much the same price as it would to put a pump kit on the unit.
The upside is also having remotes to use when the hoe is not on the tractor.
I wouldn't worry about contamination to the tractor unless you are very careless.
Always cover the ports on both sides and always wipe them off before hooking them up.
KO
/ ck30 with back-hoe good/bad #28
Why would you worry about contamination of your tractor hyd fluid by the fluid used in your backhoe? You don't worry about contamination from fluid used in your loader, or your T&T cylinders for that matter. Your expensive tractor comes with a very well-designed hyd pump/filters/cooler/reservoir system that is intended to operate implements. Use it!
/ ck30 with back-hoe good/bad #30
woods seems about $7k, kioti with separate pump about $6K. woods normally includes separate pump, local guy says easy on and off.
mike
/ ck30 with back-hoe good/bad #31
If we were talking about an attachment used on more than one tractor then Xcontamination could be an issue but on a dedicated BH for the same tractor then it doesn't seem to be a problem. The benefits of using the tractors hydraulics far outweigh any risk in the case of the CK30HST. So yeah, you're right.
/ ck30 with back-hoe good/bad #32
</font><font color="blue" class="small">( Why would you worry about contamination of your tractor hyd fluid by the fluid used in your backhoe? )</font>
I think, for the vast majority of users, the loader and T&T don't get taken off nearly as often as a backhoe does, opening up the possibility of getting dirt into the system.
With a separate pump, the tractor's main system is not subjected to this possibilty.
I use mine with the system hydraulics, but I can tell you that when I put the backhoe on, it is very difficult to get all the dirt off the connetors. Yes, I cover them when not on, and I blow them off with compressed air, but I can tell you, there's always at least a little stuff on there that gets into the system.
Hydro pumps are very sensitive to any particles of dirt, filters notwithstanding. Yes, I think Kioti has good filtering systems, but they are not infallible in any tractor.
The extra piece of mind from having a separate pump and reservoir may just be worth the extra cost to some.
John
/ ck30 with back-hoe good/bad #33
</font><font color="blue" class="small">( he suggested getting one with a PTO driven hydraulic pump instead of using the tractor's hydraulics. )</font>
Personally I would use the tractor hydraulics vs PTO pump.
With the PTO pump you have the pump to fumble around with every time you remove/install the hoe. Also it gives you another seperate system to maintain. (filter and hydraulic oil)
/ ck30 with back-hoe good/bad #34
</font><font color="blue" class="small">( With the PTO pump you have the pump to fumble around with every time you remove/install the hoe. )</font>
Vince, you make a couple of good points. I would hate to have any more hassle than is necessary myself.
However, one other thing that may be an advantage to having a separate system, and I don't know the specs, but it's possible that a separate system could be bought that has a higher pump flow if the tractor's pump capacity is a little low.
I'm sticking to using the tractor's system myself.
John
/ ck30 with back-hoe good/bad #35
Our CK30s, with the HST have a pretty substantial hydraulic flow rate. That is good for running the hoe off of the tractor's system. An older tractor or a gear model with low flow would benefit from the PTO BH. You may have to hook up the PTO pump each time but you don't have to mess with connecting the tractor hydraulics or turning that goofy diverter valve. The life of the PTO BH fluid and filter would be longer than the tractor fluid's life since it sees reduced use.
/ ck30 with back-hoe good/bad #36
On the higher flow pump...
You are at the mercy of the capacity of your sump.
If you turn the oil over too quickly, it will overheat badly and breakdown more rapidly.
If you increase the pump flow, you should increase the sump size also.
Of course this depends on the size of the original sump.
If it was already "oversized" you would be fine.
KO
/ ck30 with back-hoe good/bad #37
Yes, the hyd QA hoses are more convenient to use, versus
attaching a PTO pump. The Prairie Dog backhoe folks have
provided a gear increaser PTO pump to deal with low flow
rates on old tractors. That is not a problem with modern
CUTs in my experience.
As for contamination of fluid in a PTO pump b/h.....I have seen
numerous hoes with PTO pump and res where the fluid and
filter prob never gets changed. A quick check of the breather
on these hoes often reveals rust inside the cap and filler tube.
A tractor hyd system seals up a detached hoe extremely well.
/ ck30 with back-hoe good/bad #38
PTO pump will also require that you operate at higher engine rpm's, won't it? Noisier; more fuel consumption, but perhaps a cooler engine. Also less wear and tear on the tractor hydraulics. Yet, more things to maintain..... Hmmm much to consider.
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
Minneapolis-Moline U Tractor (A66285)
Minneapolis-Moline...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
