Ck30 wiring exposed after some land clearing.
   / Ck30 wiring exposed after some land clearing. #1
atcNick
Longview, Texas
Still shopping
I was clearing some brush on Monday using brush hog and fel. Was pretty tough on it. When I got it back home I. Priced some sites hanging from under the left side. Don't think it was like this before. Can you guys tell if do egging is unplugged or out of place.
   / Ck30 wiring exposed after some land clearing. #2
Does everything still work? Tractor start? If it starts then maybe you're looking at something having to do with lights (turn signals etc.).
   / Ck30 wiring exposed after some land clearing. #3
Once upon a time when I was doing the same thing some wire's became discontented and the famous engine light came on the dash. Looked and prodded till I figured out where the went and the light went away. Given mine is a NX series but if it's important enough there should be some sort of warning light
   / Ck30 wiring exposed after some land clearing. #4
The three "bullet" connectors are for the left marker/turn light. Look under and you'll see the other bullet connectors, match wire colors and plug together.
   / Ck30 wiring exposed after some land clearing. #5
I have done the exact same thing. I believe they are for an option we don't have, maybe a cab power supply. If you look on the right side of your machine you will see 3 more in pretty much the same are. All my lights and signals seem to be working fine. I used cable ties to secure it up more solid.
   / Ck30 wiring exposed after some land clearing. #6
The NX all seem to have a disconnected blue wire on the left side of the engine as well. Nobody seems to know what it's for either.
2017 DODGE RAM 3500 SERVICE TRUCK (A52472)
2017 DODGE RAM...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Mechanics Crane Service Truck (A50323)
2013 Ford F-550...
