CK30 Throttle
/ CK30 Throttle #1
Steve_Miller
Nova Scotia, Canada
2006 Kioti CK30HST
Can someone point me to the thread/comments a while back about tightening the throttle lever, mines starting to ease its way off quite often now.
Thanks
Steve
/ CK30 Throttle #2
I removed the return spring on mine, the spring at the engine seems to be all you need to do the job. I never could get mine to stay anywhere near 2K or higher. Works like a champ now.
/ CK30 Throttle #3
If you look under the dash on the righht side, unfortunately not in an easy location. you will see a shaft with two nuts on the bottom of it. That is the throttle shaft and the adjustment. It's very hard to get two wrenches in there. I had a few choice words when adjusting mine. The first will adjust tension and the second is used as a jam nut.
Generator Cord (A65640)
Generator Cord...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
Trimble Automated Steering GPS system (A64126)
Trimble Automated...
Kubota M6950 (A64127)
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
