CK30 Throttle
   / CK30 Throttle #1
Steve_Miller
Veteran Member
Nova Scotia, Canada
2006 Kioti CK30HST
Can someone point me to the thread/comments a while back about tightening the throttle lever, mines starting to ease its way off quite often now.
Steve
   / CK30 Throttle #2
I removed the return spring on mine, the spring at the engine seems to be all you need to do the job. I never could get mine to stay anywhere near 2K or higher. Works like a champ now.
   / CK30 Throttle #3
If you look under the dash on the righht side, unfortunately not in an easy location. you will see a shaft with two nuts on the bottom of it. That is the throttle shaft and the adjustment. It's very hard to get two wrenches in there. I had a few choice words when adjusting mine. The first will adjust tension and the second is used as a jam nut.
2013 Freightliner M2 106 Altec DC47T Insulated Derrick Digger Truck (A50323)
2013 Freightliner...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 60"...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
John Deere 915 Flex Head (A50774)
John Deere 915...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
