CK30 sticky throttle
   / CK30 sticky throttle #11
Let me offer a trick I discovered for lubing your throttle. You can easily pop off the little boot on the dash that covers the joint where the throttle lever enters the dash. The boot uncovers a rather large hole, large enough to allow you to shoot lube on all the necessary parts from above. I also shot some from below but found it very difficult to work down there.
My throttle is smooth like new now. I only used wd-40 so I may need to do it again sometime but it is no sweat from above.
   / CK30 sticky throttle #12
Highbeam, You always have the best ideas. I have been reading all about the sticking throttle and went to the storage shelter to check on mine and sure enough it will barley move. So I was just thinking about trying to spray some WD40 up there and I see your post. Thanks for all your contributions, they are very helpful! /forums/images/graemlins/cool.gif
   / CK30 sticky throttle #13
I have found that spray delayed viscousity grease is the best.
I sell the stuff and farmers, oh heck everyone, love it.
Unlike WD that goes away real quick it penetrates and stays once it thickens.
Dave
   / CK30 sticky throttle #14
</font><font color="blue" class="small">(
Unlike WD that goes away real quick it penetrates and stays once it thickens. )</font>
I agree. The WD 40 doesn't last very long. I use the spray white lithium grease that goes on easy and thickens to the proper viscosity, and stays on a long time. Don't put it on your electronic contacts though, you need the dielectric grease for those areas.
John
   / CK30 sticky throttle #15
Update.
I've not applied any of the "fixes". Here is what I've observed. My throttle does NOT stick IF I don't lower the RPMs under 1200 (approx), but will stick even time I go 1000 or less. Today, I wanted to attempt a bit more hydraulic pressure to curl my pallet forks and thought I might mometarily raise the RPM's pass the PTO red line. I felt the throttle stick about 2800. So my guess is the sticking throttle is perhaps a feature to keep us from too low or too high RPMs. Just my casual, non engineer observations /forums/images/graemlins/smile.gif
David
   / CK30 sticky throttle #16
I have the exact opposite problem. The throttle won't stick at anything over 1800 or so RPM's, it just keeps falling down to that range. I just use a bungee for now but I may try to remove the plastic and tighten it up now that I know.
   / CK30 sticky throttle #17
Noodle,
Take it apart and tighten it up, only took about 15 min, and man what a difference! You will wonder why you didn't do it sooner.......
RD
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Rooster Weathervane (A55853)
Rooster...
mixer (A55973)
mixer (A55973)
MILWAUKEE 14" Abrasive Cut-Off Machine (A59076)
MILWAUKEE 14"...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
