CK30 KL130 curl problem
   / CK30 KL130 curl problem #1
DrewL
Sandwich, MA
Kioti
with or without the toothbar, the curl of the bucket "stalls" when entering a pile of dirt.......wet or dry. It seems that is a lack of power in this function only. I have to back up to take a 1/2 bucket load at a time then reenter to fill the bucket. I've had two rocks in there the size of a Yugo with no problem so I feel the lifting capacity is in line. I also have a KB2375 hoe and no problems there...................impressive actually. 150 hours with two filter changes and one full fluid change. I always felt that the curl function was the most powerful on many machines. Any ideas? /forums/images/graemlins/confused.gif
   / CK30 KL130 curl problem #2
I have had the same problem. I try to ease into the pile a little slower and work the bucket a little. That helps but it does seem to lack in lift (curl) power in that situation.
   / CK30 KL130 curl problem #3
It is a matter of working the bucket.
Go in with the bucket angled down about 2/3, not full dump, dig in while you push forward with the tractor, start curling back the bucket, pull back a little whith the tractor if you're getting to the end of your pile, and do it again.
You can also work the bucket up and down (dump/curl) while your pushing into the pile and that will break up the soil and grab it into the bucket.
I actually go forward / reverse with the tractor in small steps while manipulating the bucket into the pile and get a full load each time.
The bucket will be dumping-curling as I go in and picking up more soil each time.
John
that's how I already approach a pile of dirt/loam. I have a pile of loam now that is about dry as it will be and it still stalls.
   / CK30 KL130 curl problem #5
When doing heavy loader work, to get the full strength of the hydraulic system on most modern tractors you need to have your engine RPMs up. Are you running at/near the PTO speed of the tractor? If not, try again with the RPMs running higher and see if that is where your problem lies. You may just be running the engine speed to low to give you full hydraulic strength.
   / CK30 KL130 curl problem #6
Good point Bob.
Well, there's always the possibility that the loader isn't working as it should. I always get some stall if I'm in the full dumped position and try to curl back without moving. I don't find the curl is the strongest on these loaders.
The powered dump actually seems stronger, like when I want to break up a pile, I put the loader down about 1/2-2/3 and push the dump to pull the dirt back. Much stronger in that position than curling.
You may want to try doing that. Break up the pile some by backdragging, dumping with the toothbar on, then go in and load it.
It's really hard to visualize exactly what's going on on this text forum!
John
   / CK30 KL130 curl problem #7
I had a similar experience when I first started using the loader. My problem was that I would drive into the pile and try to scoop up a load from the bottom up. It would never make it. Then I realized instead of trying to scoop up only one bucketful I was trying to pick up a full bucket and all the material that was above it. If you have a pile 5' high, that's a lot of weight! So I learned quickly to scrape at the pile while lifting and curling at the same time. Now I can get a full bucket every time.
Aside from that I have heard of issues with air in the system from going directly to float from high up. But that usually effects lift and not curl.
I will admit that I run at/around 1500rpm's 'cause that is ok for ground speeds and my hearing /forums/images/graemlins/smile.gif. I will try higher rpm's next time out but then my next question would be, why are my other loader or backhoe functions not compromised by lower hyd pump output?
   / CK30 KL130 curl problem #9
</font><font color="blue" class="small">( I will admit that I run at/around 1500rpm's 'cause that is ok for ground speeds and my hearing . I will try higher rpm's next time out but then my next question would be, why are my other loader or backhoe functions not compromised by lower hyd pump output? )</font>
With the extra RPM you really get more flow of the hydro fluid, I'm not really sure that you get a lot more strength, but what you get is a faster moving bucket which may help it to overcome the pressure of trying to curl. Does that make any sense?
I could not imagine trying to do any task on my CK20 at less than 2000 RPM, except for using the backhoe which I keep between 1800 and 2000.
For loading, the loader is slow at less than 2200.
I wouldn't drive around at only 1500 myself as I feel it actually puts the engine in a strain. 1800 is the least I drive around with.
John
is the hyd pump for the transmission (HST) the sane for the CK20 CK25 and the CK30?
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
Bush Hog 2615 Rotary Cutter - INOPERABLE / PARTS ONLY (A52128)
Bush Hog 2615...
200 Gallon 3-point Sprayer 30ft Boom (A52128)
200 Gallon 3-point...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
International 3788 2+2 (A52128)
International 3788...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
