Ck30, is this where I add hydraulic fluid?
   / Ck30, is this where I add hydraulic fluid? #11
Thanks. Is there a specific type of hydraulic fluid I should use?
Yes it needs to be a tractor transmission/hydraulic fluid for wet brakes.
Over the years on my gear DK 35 I have have used
Rotella heavy duty universal tractor transmission/hydraulic fluid
Napa universal premium tractor transmission/hydraulic fluid
Tractor supply premium universal tractor trans/hydraulic fluid
And they all worked fine.
I’m assuming these two ticks are the low and full marks on the dipstick for hydraulic fluid? Correct?
How exactly do I add hydraulic fluid here? I haven’t been able to find a funnel with a small enough tip to fit... I’ve managed to add some but it’s slow going and makes a huge mess.
   / Ck30, is this where I add hydraulic fluid? #15
Unscrew the large candy cane looking thing above the 3 point hitch. That's where you fill it.
Are you talking about this? It’s labeled “oil”, is that not for the engine oil?
   / Ck30, is this where I add hydraulic fluid? #17
That's hyd oil fill and vent
   / Ck30, is this where I add hydraulic fluid? #18
Yea. That's hydraulic oil. Engine oil is at the front end. Do you have a manual?
   / Ck30, is this where I add hydraulic fluid? #19
atcNick, It seems you are very new to mechanical equipment like this. Glad you are asking questions. Lots of people here that are glad to help.
Take a look at this page, It goes over your CK30 hydraulic oil and filter change.
Here also, for future reference as you get into your tractor, take a look at this Engine oil changing page, as well as the air filter, and all greasing points.
There are lots of things to know, but these few items are a great place to start.
Thank you sir!! I needed those. I bought my ck30 used and I didn’t get a manual with it, and the kioti website isn’t helpful.
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
Texaco Antique Fuel Pump Art (A55853)
Texaco Antique...
2013 Chevrolet Silverado 1500 (A55973)
2013 Chevrolet...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
1991 Cummins NT-855-G5 250kW 3-Phase Diesel Generator (A55851)
1991 Cummins...
