ck30 hydro not starting
/ ck30 hydro not starting #1
roller
Suffolk England
kIOTI CK30
Hi I have a ck30, i took the battery off my tractor the other day as we left it on a jobsite and didn't want it to get stolen, today 4 days later I go back to the tractor and reconnect the battery, it won't start, non of the lights or the horn will work, non of the dash board contol lights come on .
I took the battery back off ''after'' checking to see the leads were tight [and clean] on the battery, I took the battery away and tested it, the battery is good and fully charged, I also checked the line of fuses under the steering wheel area, all the fuses look good to me..
Any suggestions please!
/ ck30 hydro not starting #2
Check the ground and the "slo-blow" fuse out by the starter.
It's a big blocky looking fuse with tape all the way around it.
You can look into it without removing it or the tape, to see if it's good.
BTI
/ ck30 hydro not starting #4
A lot of these get bad ignition switches---that was the first thing to come to mind as a pattern failure item
Thanks guys, can anyone tell me where the ground is bolted roughly? I have looked and looked for another fuse, thanks guys...
/ ck30 hydro not starting #6
Follow the neg. cable and check the connection
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
