ck30 hydro not starting
   / ck30 hydro not starting #1
roller
Bronze Member
Suffolk England
kIOTI CK30
Hi I have a ck30, i took the battery off my tractor the other day as we left it on a jobsite and didn't want it to get stolen, today 4 days later I go back to the tractor and reconnect the battery, it won't start, non of the lights or the horn will work, non of the dash board contol lights come on .
I took the battery back off ''after'' checking to see the leads were tight [and clean] on the battery, I took the battery away and tested it, the battery is good and fully charged, I also checked the line of fuses under the steering wheel area, all the fuses look good to me..
Any suggestions please!
   / ck30 hydro not starting #2
Check the ground and the "slo-blow" fuse out by the starter.
It's a big blocky looking fuse with tape all the way around it.
You can look into it without removing it or the tape, to see if it's good.
BTI
   / ck30 hydro not starting #4
A lot of these get bad ignition switches---that was the first thing to come to mind as a pattern failure item
Thanks guys, can anyone tell me where the ground is bolted roughly? I have looked and looked for another fuse, thanks guys...
   / ck30 hydro not starting #6
Follow the neg. cable and check the connection
   / ck30 hydro not starting #7
Roller when you find the solution, please post.
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
HELI STRAIGHT MAST FORKLIFT (A51242)
HELI STRAIGHT MAST...
SCAN FOR HAULING AND FINANCING INFORMATION (A51244)
SCAN FOR HAULING...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
2014 INTERNATIONAL LF687 SLEEPER (A52141)
2014 INTERNATIONAL...
