Oil & Fuel CK30 Fuel Filter, Why Not Bigger?
   / CK30 Fuel Filter, Why Not Bigger? #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
Question for diesel experts out there. My '76 Mercedes has a monstrous type of fuel filter very thick and HD. Other diesel filters I've seen are big also.
Why does the Kioti have a gasoline-like thin filter? Could it use another filter in line with this one?
Mike
   / CK30 Fuel Filter, Why Not Bigger? #2
Unless your running some pretty bad fuel, I don't believe it is nessasary for more filter.
   / CK30 Fuel Filter, Why Not Bigger? #3
Cause---
You don't run as much fuel thru your tractor as your car.
You maintain your tractor better than your car.
It has a clear bowl thus you can see trouble.
It is all that it needs.
   / CK30 Fuel Filter, Why Not Bigger? #4
One more:
Diesel fuel quality has gone way up since 1976 through regulation and improved refinery practice.
   / CK30 Fuel Filter, Why Not Bigger? #5
<font color="blue"> Diesel fuel quality has gone way up since 1976 through regulation and improved refinery practice.</font>
Maybe? that's why it costs more than gas now. /forums/images/graemlins/smirk.gif
   / CK30 Fuel Filter, Why Not Bigger? #6
</font><font color="blue" class="small">( <font color="blue"> Diesel fuel quality has gone way up since 1976 through regulation and improved refinery practice.</font>
Maybe? that's why it costs more than gas now. /forums/images/graemlins/smirk.gif )</font>
Yeah, I'm thinking they're putting gold flake in it or something, maybe having it blessed by the Pope?
   / CK30 Fuel Filter, Why Not Bigger? #7
Get ready for another jump in price - the sulfur levels requirements for diesel go down again in 2008, plus the lower emission levels required from class 8 trucks will require all sorts of special filters on the exhaust system.
Offroad vehicles (tractors) are being debated currently. Imagine changing your 'exhaust filter' every two years on your tractor at $100 a pop. It's coming if California Air Resouirces Board gets its way. Maybe even a catalytic converter on your push mower! /forums/images/graemlins/shocked.gif
   / CK30 Fuel Filter, Why Not Bigger? #8
I think that the farm diesel that I got at the JD dealer had GREEN <font color="green"> </font> dye, after I pumped 53 gallon, and went to pay, I found out it is $2.08 per gallon.
   / CK30 Fuel Filter, Why Not Bigger? #9
From what I see and understand out west here is....Diesel goes up in the winter time due to demand for home heating oil. Price in winter out here is typically the same as premium gas. Typically, diesel goes down in the summer and cost a little less the regular gas. This year seems to be an odd case and diesel has not come down to even regular gas levels yet. I "hear" this is due to the grade of oil that the refineries have had to purchase this year....which apparently is better for gas so they are producing less diesel.
(1) Tire on Rim (A47164)
(1) Tire on Rim...
2019 DODGE RAM 3500 (A48992)
2019 DODGE RAM...
Solid Tires (set of 4) (A49251)
Solid Tires (set...
2022 Jeep Grand Cherokee SUV (A48082)
2022 Jeep Grand...
2015 FREIGHTLINER M2 ALTEC DIGGER DERRICK (A50046)
2015 FREIGHTLINER...
2017 Chevrolet Express 2500 Cargo Van (A46683)
2017 Chevrolet...
