Ck30 engaging pto grind noise
   / Ck30 engaging pto grind noise #1
atcNick
Longview, Texas
Still shopping
What configuration are you guys in when you engage your pto for brush hogging. I get a grinding gear noise and have to push the lever through it. Does it at low and high rpm. Guy I bought the tractor from says that's normal. Your thoughts?
   / Ck30 engaging pto grind noise #2
I don't get any grinding on our CK35 - sometimes it might feel a little "stiff" or a quick bump when engaging.
Especially for Brush Hogging where it's trying to spin up all that mass, I engage at idle and very gently let out on the clutch till things get moving, then throttle up.
Not trying to be a smart @$$ but (I'm assuming you have the gear model and not the hydrostatic) you do know it's a 2 stage clutch and depressing part way only disengages the transmission. To fully disengage the PTO you have to depress the clutch ALL the way thru it's range of travel. I bring this up because it was new to me coming from the old 8N Ford where depressing the clutch disengaged both transmission & PTO together. From my "muscle memory" if I wasn't moving then the PTO wasn't turning either so I had a little learning curve.
Hopefully it's this (or maybe the clutch linkage has slipped / out of adjustment and you're not getting the second stage like you think you are) and not something more serious.
   / Ck30 engaging pto grind noise #3
Mine will grind if I don't push in the clutch. Maybe your clutch is going.
   / Ck30 engaging pto grind noise #4
Will grind if you don't push the clutch pedal all the way to the floor. It also could be out of adjustment have you checked the free play movement?
I started it up this morning, looks like I may not have had the clutch all the way in. I'll check again in a week when I take it out to henland
2020 JOHN DEERE 700K LGP CRAWLER DOZER (A52707)
2020 JOHN DEERE...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
Hyster Forklift (A55973)
Hyster Forklift...
2013 Audi Q7 AWD SUV (A55853)
2013 Audi Q7 AWD...
2017JOHN DEERE 450K LGP CRAWLER DOZER (A52707)
2017JOHN DEERE...
2016 GMC SIERRA 3500 SERVICE TRUCK (A57192)
2016 GMC SIERRA...
