ck30 BH connecting hydraulic lines
   / ck30 BH connecting hydraulic lines #1
DIRTCUTTER
New Mexico
CK30 HST
Took off the BH for the first time with no problem. Now I cant reconnect the Hy hoses from the BH to the tractor. Am sure all the air is out of the lines.
   / ck30 BH connecting hydraulic lines #3
I had the same problem the first time.
I moved all the levers to relieve the pressure, still wouldn't go on.
I took a screwdriver to the "pin" on the female connectors and relieved the pressure (have a rag handy).
Went right together.
Hope it helps.
Tom
   / ck30 BH connecting hydraulic lines #4
Hope it helps.
Tom
Dodger tried what you suggested, still not luck. Let me ask you how long did you hold the pin in and how much fuild did you lose? by the way thanks for the reply I need that BH.
   / ck30 BH connecting hydraulic lines #7
A second or two at the most. It was a nice little spray /forums/images/graemlins/crazy.gif
Make sure the diverter valve is in the 3 PH position, otherwise you'll have pressure on the rear remote.
The only other thing I can think of: put the bottom (return line on first).
I also make sure the tractor is off (I guess to make sure there is no pressure)
Let me know what happens.
Tom
   / ck30 BH connecting hydraulic lines #8
Tom
Dodger, what I ended up doing is cracking the lines on the backhoe, that did it. I want to tell you I spend most of the day on those connections in the heat, not a fun day. Connecting the backhoe to the tractor that took a little more that i was thinking it would. But now I know and next time should be a little easier and faster. Thanks once again for the advice, am off to do some digging. thanks
KSI Conveyor (A52748)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2024 Icon I40L Electric Cart (A50324)
2024 Icon I40L...
1984 AM GENERAL HMMWV HUMVEE (A52141)
1984 AM GENERAL...
2000 Miller Pipe Pro 304 Welder/Generator S/A Towable Trailer (A50322)
2000 Miller Pipe...
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
