CK27 No power/electricity
   / CK27 No power/electricity #1
zumsel
Nova Scotia, Canada
Kioti CK27 HST
Hi,
I had to replace the solenoid of the starter on my CK27 and now my tractor doesn't show any battery power at all. The battery is fully charged, I checked that, and all the fuses are okay (the one on the right side of the dashboard). Are there any other hidden fuses that I have missed, or can you think about any other problem why I have no power. All lights on the instrument panel are dead. I'm clueless.
Thanks for any ideas and suggestions.
   / CK27 No power/electricity #2
Check the wire connections again. It sounds like you mixed up the power wire and hooked it to ground or it is not connected. Or the cable is bad and removing it finally broke it internally.
   / CK27 No power/electricity #3
Check that your slo-blo fuse out by the starter is good.
It's a big fuse usually almost completely covered with electrical tape.
You may have pulled it part way out or popped it.
Check your grounds, both at battery and frame.
A terminal can look clean but not be clean.
BTI
   / CK27 No power/electricity #4
Check your ground connection at the battery, look real close cables get corroded and you never see it untill you take it apart. . . JOHN
New/Unused 8in Bucket (A57454)
New/Unused 8in...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota LX2620 (A53317)
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
HARRINGTON CHAIN HOIST (A52708)
HARRINGTON CHAIN...
2022 Ram 2500 (A55973)
