Oil & Fuel CK2610H Hydraulic Leaks
   / CK2610H Hydraulic Leaks #1
richard22c
SW VIRGINA
Kioti CK2610HST
I am very thankful for this forum and all the input owners & dealers have contributed.
I have 48.7 hours on new CK2610H. Was wondering if other owners of this same model have experienced hydraulic leaks? How hard they have pushed the machine, how many hours w/o leaks, or problems?
The seal where 4x4 shaft goes into rear transfer case was replaced by dealer once under warranty, and it is leaking again. Dealer is coming out the look at it.
Have another leak looks like coming from drive train and dripping on 4x4 shaft. Have photo if needed.
   / CK2610H Hydraulic Leaks #2
Had a leaking cylinder on the FEL that was replaced when I first got the machine....At 60hrs now without a drop anywhere.
   / CK2610H Hydraulic Leaks #3
Just hit 25 hours and no problems but mine is a gear drive.Been a great tractor so far and have got a ton of work done.
   / CK2610H Hydraulic Leaks #4
I would have them confirm the casting where the seal goes is ok. A few people have had bad castings with voids and where it was machined for the bearing and seal opened up the void. Once this happens there is no good way to seal it besides replacing the casting.
   / CK2610H Hydraulic Leaks #5
Sadly, do not assume that the dealer performed a proper repair. I had a leaking rear axle and the dealer resealed under warranty. They resealed BOTH sides even though one side wasn't leaking. Now, after shy of one year (about 100 hrs) that one side is leaking (tractor is now at their shop). This current leak cannot be blamed on the factory, only on the dealer.
   / CK2610H Hydraulic Leaks #6
I have a rear axle seal leak, very small.Dieselbound thanks for sharing your experience. I now know what to expect if I take it to the dealer. Might be a casting issue. Great tractor though.
   / CK2610H Hydraulic Leaks #7
OP, post pic; its always useful to show pics.
Thanks for your responses. Sorry have not replied sooner. I need to change alert settings.
Ok Diesel Bound.. I will post here and your link. Dealer "said" he has not heard this was a common problem.
Attached is photo of leak after repair. Also pic of new leak that has developed.
Leaks on new equipment one pays so much $$ just drive me nuts!
I am hoping the seal was just installed incorrectly, or there is a burr on shaft, or similar.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
2025 Swict 78in Bucket Skid Steer Attachment (A51691)
2025 Swict 78in...
