CK2610
   / CK2610 #1
12Bravo
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
Anyone had an error code of 007 on a CK2610?
Just turn tractor off and now it's acting all kinds of funny. Electrical dash lights want to work then not work. The ignition switch is kind of sloppy, would this cause an error code 007?
Thanks in advance
   / CK2610 #2
I don't think that tractor can throw codes since it used a mechanically injected engine and therefore no ECM to throw codes. Are you sure it's not just the hour meter acting up?
   / CK2610
How would I test that?
When I turn the key, the electrical kind of goes nuts. It cranked once but wouldn't start. Where the hour meter is, all the way to the left "007" appears.
I'm not sure where to start since I don't have an ECM or codes.
   / CK2610 #4
Probably not related, buy I had tachometer totally weird out on mine with around 120 hours. I did not look at any other dashboard indications during this event. It was running and I looked at tach as I was running a brush hog, and it was pegged off the numbers on the high side of 4000 RPM. I turned it off and started it, and it dropped to 3600. I think another 'start and stop' and it was back to normal and problem hasn't reappeared.
You mention sloppy key (do you have a lot of keys on the ring?) and don't say if stored outside. Spray some contact cleaner in there and operate a few times as Item 2 below notes that it could be your problem. I guess I would do as many have mentioned on this forum and make sure your battery ground attachment is clean without paint under the landing spot. Mine was poor from the factory in this regard. I doubt it matters, but disconnecting the battery for a few seconds could make sure you're somewhat at baseline, but wouldn't affect a truly stuck relay/solenoid.
The factory service manual for checking hour meter operation is
1. Check fuse- 5 amp
2. Ignition Switch: 'Check proper connection with it in the "ON" positions: A-B-D' The image shows disconnection of the key switch at its first connector and checking those pins for continuity.
3. Check the regulator for operating power.
Also, a few more descriptive terms in the title when you post might get more responses. Good luck. For what it's worth, Toukow
PT 12' x 6' 4-wheel Wagon (A44502)
PT 12' x 6'...
2016 Jeep Grand Cherokee Laredo SUV (A44572)
2016 Jeep Grand...
2020 International MV607 Truck, VIN # 1HTEUMML3LH587955 (A44391)
2020 International...
2018 Rock Solid 8x28 Cargo Trailer  Generator & A/C, Work-Ready (A44789)
2018 Rock Solid...
Caterpillar 420F IT (A44501)
Caterpillar 420F...
John Deere 5410 Tractor (A44391)
John Deere 5410...
