ck2610 smoking
   / ck2610 smoking #1
cowbridge
Slower Lower, Delaware
Kioti CK2610HST Woods BB60XC
Barely a year old, 110 hours. I did the 50 hour maintenance by the book. It starts quickly as is should but coughs and smokes a lot for around 10-20 seconds. It puts out a huge amount of smoke and it's been getting progressively worse. Doesnt matter if its cold or mild out. Seems to operate as normal after it warms up a bit.
Should I be concerned? What should I do to clear this up? It stinks my shop up unbearably every time I start it up
   / ck2610 smoking
No. There was no change at all after the 50 hour service. This issue started in the past month or so
   / ck2610 smoking #4
Have you tried double cycling the glow plugs?
   / ck2610 smoking
No I havent. Does that mean turning the key till the glow plug light goes off, then repeating before starting?
   / ck2610 smoking #6
Sounds like an injector issue.
I would call for service tech to take a look at it.
   / ck2610 smoking
Would using regular diesel fuel and not the red dye off road fuel have anything to do with it?
   / ck2610 smoking #9
Mine smokes pretty good for 10 seconds or so after a cold start. Has always done so.. Just a puff of smoke when it's warm out..
   / ck2610 smoking #10
No. Dye makes no difference. Same fuel one is just charged tax while the other is not. I used dyed (off road) diesel 90 percent of the time. No issues.
2015 Chevrolet Cruze Sedan (A50324)
2015 Chevrolet...
1981 FMC Link Belt Crane (A50120)
1981 FMC Link Belt...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
2020 Caterpillar...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2016 John Deere 6130M (A50120)
2016 John Deere...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
