CK2610 FL2610, CK2610 FL4030, or CK3510 FL4010?
   / CK2610 FL2610, CK2610 FL4030, or CK3510 FL4010?
Will do, thanks for the pics, clean rig!
   / CK2610 FL2610, CK2610 FL4030, or CK3510 FL4010? #12
Agreed, even with loaded tires the rear comes up a lot. Weight box is going on this weekend.
Curious what your opinions on the 4030 loader are? I really don't like it, lots of flex and noise.
Everything seems tight so maybe it just the design. I have the 66" bucket which I don't think I would do again.
Jer
Have fun with that new tractor. The bucket has a much higher quoted capacity but you will need to install ballast or a counterweight on the 3point hitch in order lift the 1800lbs quoted. I learned that mine would safely lift about 50% before the rear tires wanted to lift. Once I installed a concrete counterweight I was much more stable and comfortable moving loads around.
UNUSED SDLANCH SDLD25 DUMPER (A58375)
UNUSED SDLANCH...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
Hot Pressure Washing Equipment Set (A56857)
Hot Pressure...
1629 (A57192)
1629 (A57192)
GENIE S-60 MANLIFT (A58216)
GENIE S-60 MANLIFT...
