CK2610 Does this thing even have high beam lights?
   / CK2610 Does this thing even have high beam lights?
My CK3510 has two wires and connectors that come out at the base of the ROPS, near the fuel tank. These are factory, and power is supplied when the ignition is on, I wired a switch for work lights that I mounted on the ROPS!
I had seen this noted in other posts, and found mine on the left side of the CK2610 ROPS as well. Seems like a great solution as long as your lights do not exceed the ampacity of the wire/fuse. Seems like most of the lights can operate at a wide range of voltages, so voltage drop should not be an issue. I ran dedicated #12's for mine with an auxiliary relay, but given my low load could have probably gone your route.
I need to breakdown and buy the $180 service manual in order to get a good schematic for mine. I may ask for it for Christmas.
1565 (A57192)
1565 (A57192)
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
