CK2610 and Box Blade
   / CK2610 and Box Blade #11
I've got a 60" land pride to use on mine and it works well.
   / CK2610 and Box Blade #12
Wondering how your 6ft BB works on your CK2610? I am looking at getting a BB very similar 496lbs and have the exact same tractor Just wondering if it is to much for the tractor or not?
   / CK2610 and Box Blade #13
Asking if a 26 HP tractor will handle a 5 or 6 foot BB is pretty subjective. I think most people can run a 5 or 6 footer on a 26 HP tractor and be just fine, given the right conditions and use. I ran a 4 foot BB on my 2305 and ran out of traction before I ran out of HP to drive the wheels. The biggest thing is how much weight you can apply to the ground. In contrast, i have a 6 foot BB that weighs around 650 lbs, my tires aren't loaded and I have no weights. My tractor pulls it just fine in low gear, and that's with an HST trans.
   / CK2610 and Box Blade #14
I think the BB on my ck4010 is 60”. My tractor has a cab and loaded tires, but is still too light to pull it real well. I can certainly stall the engine if rpm is too low, but mostly it’s traction limited.
   / CK2610 and Box Blade #15
Yes, I think my next "mod" will be to load up my tires. I have a ballast, but I can't haul the ballast and the BB at the same time.
   / CK2610 and Box Blade #16
I run a Woods BSM72P (72"). Not cheap but at 680lbs I am also using it as ballast :)
Probably the maximum width you want on a CK2610, it struggles a bit for traction with a box full of sand in slight uphill inclines (needs the diff lock). May be better with loaded tires. I just take smaller cuts. I wanted the wider blade so 2 passes would do my 12' wide laneway.
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
SCAN TO RECEIVE TEXT UPDATES (A57192)
SCAN TO RECEIVE...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
24" EXCAVATOR BUCKET (A52707)
24" EXCAVATOR...
