krullro
Oh, I set a budget of $20K for a tractor with FEL, BH and box blade. I really liked the Kubota B series with more HP and a 3 speed but I had 3 quotes and all were in the $30K range. The CK3510H was around $26K if I remember.
Dealer should have had the lines up higher in the first place IMO.
Why would anyone mounting a loader leave the hydraulic lines dangling down like that at the dealership ???
View attachment 439155Seems to be a tough choice for more than me. It came down to weight, power and convienience. The Kioti has a treadle peddle which I don't like. I prefer the LS two pedal system. MUCH easier. The Kioti has a much higher hydro fluid pump rate and about another 600lbs on the ground for earth moving. The Kioti also cost about $1.5K more. I bought the Kioti and am really re-considering my choice. The Hydraulic lines to the loader are horrible on the Kioti! I had to loosen them all and get them higher up. Snag potential is stupid.Tied them to the loader bracket so it's all good now but ****. It's a great machine but I'm not sure with the extra weight and warranty if it really beats the LS. You really need to sit on both! View attachment 439152View attachment 439153View attachment 439154View attachment 439155
Even w/ the lighter overall weight, the LS has almost 20% more lift capabilities over the Kioti. Just remember, it is very easy to add overall weight but, impossible to add lift weight. Filling the tires on the LS will add over 300lbs. alone. The XJ FEL is 200lbs heavier than the CK FEL also. LS has a 5 year warranty -KIOTI has 4 year warranty.
