ck25
sonny
Lillian,Texas 76061
M9000-L2900(kubotas)
my friend has a kiote ck25,with a front end loader,yesterday,the rear hyd.would not raise at all,the tractor only has 50hr,so it is just like new,i thought there might be a switch or sumpin?,,that would case it not to raise?thanks for any help-sonny
/ ck25 #3
Not so sure it is the same issue as the CK25 doesn't have draft control but you are correct that several possibilities were discussed in that thread.
Does the OP's friend's CK25 have a rear remote? If so perhaps the lever is engaged. Put it in neutral.
OP mentioned that the 3PT does not go up. Is it up or down that is the problem? If it won't go down then the Mita Load Sensing valve (near operator's heel) may have been turned all the way to the slow position.
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
Komatsu PC138US (A64126)
Komatsu PC138US...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
2022 EZ-GO ELITE...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
