ck25
   / ck25 #1
sonny
Lillian,Texas 76061
M9000-L2900(kubotas)
my friend has a kiote ck25,with a front end loader,yesterday,the rear hyd.would not raise at all,the tractor only has 50hr,so it is just like new,i thought there might be a switch or sumpin?,,that would case it not to raise?thanks for any help-sonny
   / ck25 #3
Not so sure it is the same issue as the CK25 doesn't have draft control but you are correct that several possibilities were discussed in that thread.
Does the OP's friend's CK25 have a rear remote? If so perhaps the lever is engaged. Put it in neutral.
OP mentioned that the 3PT does not go up. Is it up or down that is the problem? If it won't go down then the Mita Load Sensing valve (near operator's heel) may have been turned all the way to the slow position.
Bush Hog 287 3 pt Mower (A50514)
Bush Hog 287 3 pt...
International 1420 Combine (A50514)
International 1420...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2017 JLG 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG 10054...
Poly Round Bale Ring (A50515)
Poly Round Bale...
