CK25 vs. CK30
   / CK25 vs. CK30 #11
I was quoted today with front end loaders:
ck25
gear $14,795
hydro $15,837
ck30
gear $16,458
hydro $17,240
I also was quoted a L2800DT Kubota (29 hp)with loader
gear $14,400
hydro $15,400
I never would have thought the Kubota being cheaper....:confused:
Is there a big difference?
   / CK25 vs. CK30 #12
Big difference??? The Kubota guys will answer that for you. The KIOTI was a better fit for me. When I was shopping, the price difference was a little closer with KIOTI being more. The Kubota L3130 is similar in HP, so you could throw that one in there too I guess. They are all good machines.
   / CK25 vs. CK30 #13
When comparing across brand lines, be sure to compare all the specifications. LIttle things mean a lot, Things like synchromesh tranmsission compared to sliding gears, 2 stage clutch, weight, higher lift capacity at 3 point, size of components like axle housings, etc, then there are the little niceties like the tilt steering, adjustable backrest, extendable lift arms, easy to adjust sway bars on the hitch. warranty. I run into this with my customers, they sometimes get caught in a shell game, end up with things like "semi shuttle" transmissions with reverse on the hi lo range lever or lined up with 2nd gear on a stick coming out of the top of the transmission...the other orange tractor (not as pretty a shade IMHO ;-). has a lot of models, some are great tractors and some are low cost tractors, you have got to compare apples to oranges, or is it oragnes to oranges....
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2023 CATERPILLAR 307.5 EXCAVATOR (A51242)
2023 CATERPILLAR...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
